Xantia V6 Cutting out and Starting Problems
DHallworth
x 167
Unread post by DHallworth »
Our Xantia V6 seems to be giving problems at the moment.
It started to be hesitant and snatching when moving off until I changed the fuel filter and that seemed to cure that, guess it was just being starved of Petrol.
Now it seems to be cutting out, the revs fluctuate to suit it's temperament and when it's remotely warm, even after running for 2 minutes it seems to refuse to start.
Tonight I just managed to coax it into starting, and when it did start it seemed like there was a plume of grey smoke from it. I ran the Lexia on it and it told me there was a temperature sensor giving a bad reading.
Only problem is it didn't tell me which one it was likely to be. Instinct tells me it's likely to be the brown sensor, is this the one that talks to the Bitron box?
Thanks in advance guys.
David.
'98 Xantia Activa V6 :-D
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
x 1454
Unread post by xantia_v6 »
It won't be the brown (bitron) sensor, as that only affects the cooling fans and A/C. The engine ECU uses the green sensor (I think). A faulty temperature sensor can cause very poor running.
I don't think that either of them are easy to get at. I think that the Lexia actually tells you the temperature measured by the green sensor, so you should be able to get a "second opinion".
Was the sensor fault current, or just a stored fault?
DHallworth
x 167
xantia_v6 wrote:It won't be the brown (bitron) sensor, as that only affects the cooling fans and A/C. The engine ECU uses the green sensor (I think). A faulty temperature sensor can cause very poor running.
From memory without going and checking again, I think the temperature sensor was reading a constant 30 degrees.
David.
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
x 8370
The Green (ECU) sensor is easy enough to get to. It's the brown Bitron that's a pain..
This pic shows it, just below the lower green arrow... The original picture was done to show the bleed valve locations.
Don't forget there is also a temperature sensor on the airbox by the idle air hose...
30 degrees F or C?
x 1454
30 degrees may be a default limp-home value if the ECU has detected a failed sensor, if so, it should start and run OK when cold, but will be rather rich after it has warmed up.
The problem could of course be a broken/corroded wire to the sensor, rather than the sensor itself.
DHallworth
x 167
Is there any way of testing the sensor?
Would be handy if I were able to tEst it's resistance to find out if it's knackered or not.
Thanks guys
David.
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
x 8370
I bcan give you a ball-park resistance reading later today David.
It'll be whatever themperature my workshop was at the time of reading.
DHallworth
x 167
Thanks Jim,
If I take the sensor out and change the temperature I should also be able to see it changing soil do that this evening too.
David.
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
hmm I wonder if this is whats causing a missfire when cold on my V6... once warmed through shes perfect through the rev range, so I cant see it being coil packs, also has new plugs...
Paul
A very sad...
1994 XM 2.1 d auto
x 8370
citroenxm wrote:I cant see it being coil packs
No, coils will play up when hot. very rarely do theu fail when cold..
citroenxm
Fallen Hero
x 70
No, which sensor then Jim???
Time to play the guess game, OR have you a set of known good ones I can plonk in when shes next on the repair list..?? :wink: :lol: :lol:
Paul
A very sad...
1994 XM 2.1 d auto
x 8370
citroenxm wrote:No, which sensor then Jim???
Lexia :wink: You have one haven't you Paul?
David, green sensor reads 2.9K at 21 Degrees...
DHallworth
x 167
Brilliant, Thanks Jim, I'll check this one tonight.
A new one from Cit is £31.
I'll warm it up and cool it down and see if I can get a different reading from it. If I can then I'm guessing it's another wiring fault like the heater on this blasted HDi.
David.
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
MikeT
x 232
Unread post by MikeT »
I just replaced mine on the 1.9TD but it was about 2/3 that price. Do you know the part number? It's possible they're the very same part.
DHallworth
x 167
MikeT wrote: I just replaced mine on the 1.9TD but it was about 2/3 that price. Do you know the part number? It's possible they're the very same part.
I do indeed...
Part number given to me by Citroen Glasgow was 133891.
I should also say it was £31 + VAT so will be about £38.
Are they the same between Petrols & Diesels?
David.
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
