c5 2.2 hdi automatic mk 2 gearbox questions
veralum
Unread post by veralum »
which one do I have?
can i change the flluid? (working perfectly but at 103k think would be good idea)
which fluid does it use and how much? (price and quantity)
x 1055
Unread post by wheeler »
The box coupled to the 2.2 HDi will be the ZF4HP20 box & it takes a special oil, you must not use normal ATF.
x 5672
The only fluid for a 4HP20 (and AL4) is Esso LT 71141. As you say, golden and smelling vaguely of cat's pee.
Take a gander at this thread.
Also Jim's Excellent Autobox Adventures :D
x 8400
Absolutely. Only ever use the pukka Esso LT71141. Nothing else is suitable. The Esso stuff is made from essence of cat and this will be obvious when you smell it! It's a rich golden colour is known as liquid gold on account of the cost of it....
You can order it from various on-line sources such as Automatic Choice but it is only available in 20L or 205L drums. 20L costs about £130 (ouch)
You'll only manage a partial change as half the oil is trapped in the torque converter and will not drain. Reckon to drain about 4.5 litres. To ensure a full change, do at least three partial changes at shortish intervals.
There is a special procedure for refilling and checking the level, for which ideally you need a Lexia to measure the temperature.
Be careful not to overfill as it will leak out of the driveshaft seals.
Here is the official procedure for draining and checking level.
Citroen and Peugeot dealers sell the oil in 2L bottles under part number 9736.22.
It cheaper, bearing in mind the need for the partial changes, to get a 20L drum.
mooseshaver
Unread post by mooseshaver »
Hello this may be nonsense, but I found this "Update to note that Valvoline MERCON V is also a confirmed suitable ATF for ZF trannies. (manufacturer statement)
" On this website
http://www.taligentx.com/passat/maintenance/atfchange/
Its aparently olis that can be used instead of Esso Liquid Gold.
C5 III Tourer 2.0 HDi 163 Auto Exclusive
Gone cars.
C5 2.2 HDi Exclusive Estate auto 57. Awesome car. Sadly Could not be fixed by Citroen.
C5 1.6 HDi VTR Estate 56. Traded in.
C5 2.2 HDi SX Estate 02. Drowned in the floods of 09.
C3 1.4 HDi 92 SX 52.
Saxo 1.1 East Coast.
hirsty
x 9
Unread post by hirsty »
Reading the letter from the Technical Director of Valvoline please be aware that although it can be used as a replacement i.e. total changeover of transmission fluid, they do not recommend mixing with Esso LT71141. If this is the case, can the box and torque converter be totally drained without removal?
Keith
98 Xantia Mk2 2.0 16v Auto Exclusive 160k + Now gone to Citroen Heaven
2004 C5 Mk 1 2.0 8V VTR Estate - current. Now with leather.
x 8400
hirsty wrote:If this is the case, can the box and torque converter be totally drained without removal?
No, not a chance :( Even the castings of drained gearbox retain a good half litre in its nooks and crannies and it is absolutely impossible to fully drain a torque convertor however hard you try. You think you've drained as much out as possible and then another load appears.
All this oil retention makes them very messy to dismantle and work upon.
To drain totally would mean a full strip, new filter, a rinse out and a new torque convertor.
Makes LT71141 look cheap!
cachaciero
x 9
Unread post by cachaciero »
This company apparently sells Lt71141 in 1 litre containers mind you have to buy 12.
www.oil-store.co.uk/Mobil-ATF-LT-71141-518.html
cachaciero
2006 Toyota Prius T Spirit
2001 2.2 C5 Exclusive SE
1996 XM 2.1 TD Auto VSX
1987 CX 2.5 Gti Turbo II dead
1984 Ford Scorpio
1981 CX 2.4 Pallas Auto
Renault 21
1220 GS Club
Rover P6 2000TC
