Does the Phase 2.0 HDI have a DPF fitted? Or was it only on the 2.2 like the Phase 1?
C5 Phase 2 2.0 HDI - DPF?
- x 1940
AFAIK all versions of HDi on the Phase II have the DPF (FAP).
zilly
zilly
Citroenmad
- x 110
Yes, every facelifted C5 diesel has a FAP filter. Except 1.6HDi 'DESIGN' models, which do not have a FAP filter. Ive no idea why they dont, but thats the one id be going for. 1.6HDi LX and VTR have FAP filters.
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
03 Seat Arosa 1.0S
zilly
Citroenmad
- x 110
The 138 2.0HDi is great though, ours drives so smoothly, certainly nicer to drive than the 2.0 110, which is good anyway.
Though if your going from a 2.0 110 manual to a 2.0 138 auto you might not notice as much difference, as autos sap a bit of power usually.
Our manual does around 44-45MPG and carries heavy loads.
03 Seat Arosa 1.0S
03 Seat Arosa 1.0S
zilly
Citroenmad
- x 110
Is that actual MPg from your 2.0 110 or is that the trip reading. As the 110s usually read under and the 138s read over.
03 Seat Arosa 1.0S
03 Seat Arosa 1.0S
zilly
Citroenmad
- x 110
My car, 2.0 110, does around 43/44MPG too, however i never take it easy. I had 53MPG last week on a trip to edinbourgh and back.
03 Seat Arosa 1.0S
03 Seat Arosa 1.0S
zilly
Citroenmad
- x 110
If you have a FAP, which you do, you will have the eolys fluid. Which i think can be seen if you remove one of the heat sheilds in the middle of the car on the N/S, you should see a tank, and you can actually see fluid inside it.
03 Seat Arosa 1.0S
03 Seat Arosa 1.0S
RKM
