C5 Phase 2 2.0 HDI - DPF?
zilly
Unread post by zilly »
Does the Phase 2.0 HDI have a DPF fitted? Or was it only on the 2.2 like the Phase 1?
x 1901
AFAIK all versions of HDi on the Phase II have the DPF (FAP).
zilly
Thanks Paul that's what I thought..........have you got any references to confirm?
zilly
Well I just found one on Ebay listed for the 04-08 2.0 HDi C5 so I guess they do have them!
Citroenmad
x 110
Unread post by Citroenmad »
Yes, every facelifted C5 diesel has a FAP filter. Except 1.6HDi 'DESIGN' models, which do not have a FAP filter. Ive no idea why they dont, but thats the one id be going for. 1.6HDi LX and VTR have FAP filters.
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
zilly
Thanks. Don't really fancy the 1.6 as it has no more power than my current 2.0HDi and I'm looking for an auto next time round.
Citroenmad
x 110
The 138 2.0HDi is great though, ours drives so smoothly, certainly nicer to drive than the 2.0 110, which is good anyway.
Though if your going from a 2.0 110 manual to a 2.0 138 auto you might not notice as much difference, as autos sap a bit of power usually.
Our manual does around 44-45MPG and carries heavy loads.
03 Seat Arosa 1.0S
zilly
My manual does around 43 mpg and spends most of its life at 70 on the motorway carrying just me .....I've always been a bit disappointed in the fuel consumption to be honest, so I reckon a 138 2.0 auto or even a 2.2 won't be a great deal worse!
Citroenmad
x 110
Is that actual MPg from your 2.0 110 or is that the trip reading. As the 110s usually read under and the 138s read over.
03 Seat Arosa 1.0S
zilly
That's real mpg, tank to tank........43.5 is probably the right number tbh. And I really do take it easy! I have a 60 mile round trip for work, 56 of which is motorway.
The trip computer reads about 1 mpg under on my car.
Citroenmad
x 110
My car, 2.0 110, does around 43/44MPG too, however i never take it easy. I had 53MPG last week on a trip to edinbourgh and back.
03 Seat Arosa 1.0S
zilly
I must be doing something wrong......or there's something wrong with my car.....best I've ever had was 46 on a long steady motorway journey.
RKM
eolys
Unread post by RKM »
I have a 56 plate C5 2.0 HDi 16v and was told by a Citroen dealer that it does have a FAP and the eolys fluid but a specialist tole me that i does have a FAP but no eolys.
So, which one is it?!
R
Citroenmad
x 110
If you have a FAP, which you do, you will have the eolys fluid. Which i think can be seen if you remove one of the heat sheilds in the middle of the car on the N/S, you should see a tank, and you can actually see fluid inside it.
03 Seat Arosa 1.0S
RKM
So, does your 138 C5 have eolys? I would have thought that your car would be the same as mine.
R
