CITROEN XSARA PICASSO 1.8
ok have a little prob on my CITROEN XSARA PICASSO 1.8i petrol 51 plate
it is the front screen washers every time i pull the stick back to clean windows no water but it comes from back?but you got to twist the stick to make back ones work with water with is working ok,so is there 2 pumps in the water bottle,or can it be down to the stick
- My Cars: M reg Xm S2 2.1td Auto Exclusive. 269k and rising
L reg XM S1 V6 12v Manual SEi
L 94 XM 2.1 TD auto total resto
2008 Peugeot 207 Sw 1.6 16v hdi. 217k and rising
2010 Peugeot 207 SW 1.6 8v HDi 161k and rising - x 71
If its the same setup as Xantias, it uses a single motor, and its a matter of simple spinning the motor one way for front wash, and the other way for rear wash...
Paul
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
column stick
citroenxm wrote:If its the same setup as Xantias, it uses a single motor, and its a matter of simple spinning the motor one way for front wash, and the other way for rear wash...
Paul
hi mate iam bit lost what do u mean spin motor one way for front and other way for rear?is that the column stick your on about
Sorry,
What I was trying to explain was what type of system it uses.. It could be a single motor.. Id more incline to blame the motor and not the stalk..
I was trying to explain how the motor operates if its a single motor setup..
Paul
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
- My Cars: 07 Citroen C6 V6 HDi Exclusive - Red
07 Citroen C5 HDi VTR - Red
09 Citroen C3 1.4i VTR - Silver
01 Citroen Saxo 1.1i Forte - Mango Orange
93 Ford Mondeo 2.0i GLX
19 Hyundai i10 - x 110
- mooseshaver
My previous C5 had 3 pumps and needed a fourth. All of them had exactly this fault.
It started after the cap on the water tank vanished I believe, so I assume something was getting into the tank and damaging the pumps.
Gone cars.
C3 1.4 HDi 92 SX 52.
Saxo 1.1 East Coast.
Gone cars.
water
wheeler wrote:It's a single pump on the picasso & changing it will most likely cure the fault.
A 51 plate probably wont have Com2000 anyway.
cheers but is there 2 feeds that come off the the pump,because the pump is still working,but not working the front,like i said in 1st post when i pull the stalk to clean front window the the water is coming from back not front lol
Re: water
I totaly understand the problem, It's still most likely a faulty pump. It's a fairly common problem.lasthope wrote:wheeler wrote:It's a single pump on the picasso & changing it will most likely cure the fault.
Re: water
cheers mate i will have look over the week end is it an easy job like,do i need to take wheel off then the black cover?wheeler wrote:I totaly understand the problem, It's still most likely a faulty pump. It's a fairly common problem.lasthope wrote:wheeler wrote:It's a single pump on the picasso & changing it will most likely cure the fault.
'13 3008 1.6 HDi GripControl - x 995
There's info about just this fault half way down the page on the Picasso forum: http://www.citroenpicasso.org.uk/picass ... topic=8846
cheers
RichardW wrote:There's info about just this fault half way down the page on the Picasso forum: http://www.citroenpicasso.org.uk/picass ... topic=8846
cheers richard good tut that
