CITROEN XSARA PICASSO 1.8
lasthope
ok have a little prob on my CITROEN XSARA PICASSO 1.8i petrol 51 plate
it is the front screen washers every time i pull the stick back to clean windows no water but it comes from back?but you got to twist the stick to make back ones work with water with is working ok,so is there 2 pumps in the water bottle,or can it be down to the stick
citroenxm
- Fallen Hero
- x 70
If its the same setup as Xantias, it uses a single motor, and its a matter of simple spinning the motor one way for front wash, and the other way for rear wash...
Paul
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
lasthope
column stick
citroenxm wrote:If its the same setup as Xantias, it uses a single motor, and its a matter of simple spinning the motor one way for front wash, and the other way for rear wash...
Paul
hi mate iam bit lost what do u mean spin motor one way for front and other way for rear?is that the column stick your on about
citroenxm
- Fallen Hero
- x 70
Sorry,
What I was trying to explain was what type of system it uses.. It could be a single motor.. Id more incline to blame the motor and not the stalk..
I was trying to explain how the motor operates if its a single motor setup..
Paul
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
Citroenmad
- x 110
- x 1055
mooseshaver
My previous C5 had 3 pumps and needed a fourth. All of them had exactly this fault.
It started after the cap on the water tank vanished I believe, so I assume something was getting into the tank and damaging the pumps.
C5 III Tourer 2.0 HDi 163 Auto Exclusive
Gone cars.
C5 2.2 HDi Exclusive Estate auto 57. Awesome car. Sadly Could not be fixed by Citroen.
C5 1.6 HDi VTR Estate 56. Traded in.
C5 2.2 HDi SX Estate 02. Drowned in the floods of 09.
C3 1.4 HDi 92 SX 52.
Saxo 1.1 East Coast.
Gone cars.
lasthope
water
wheeler wrote:It's a single pump on the picasso & changing it will most likely cure the fault.
A 51 plate probably wont have Com2000 anyway.
cheers but is there 2 feeds that come off the the pump,because the pump is still working,but not working the front,like i said in 1st post when i pull the stalk to clean front window the the water is coming from back not front lol
- x 1055
Re: water
I totaly understand the problem, It's still most likely a faulty pump. It's a fairly common problem.lasthope wrote:wheeler wrote:It's a single pump on the picasso & changing it will most likely cure the fault.
lasthope
Re: water
cheers mate i will have look over the week end is it an easy job like,do i need to take wheel off then the black cover?wheeler wrote:I totaly understand the problem, It's still most likely a faulty pump. It's a fairly common problem.lasthope wrote:wheeler wrote:It's a single pump on the picasso & changing it will most likely cure the fault.
- x 1055
- x 1493
There's info about just this fault half way down the page on the Picasso forum: http://www.citroenpicasso.org.uk/picass ... topic=8846
lasthope
cheers
RichardW wrote:There's info about just this fault half way down the page on the Picasso forum: http://www.citroenpicasso.org.uk/picass ... topic=8846
cheers richard good tut that
