Hiya all, I think my cat has gone. Originally it was thought that the back box was catching the bumper but after a shuffle it was still making the horrible vibrating noise at about 2000 revs, it sounds like the cat
Preferably i would like it replaced by Fri for ace cafe, but if not im sure another few days wont hurt? Has anyone got anywhere they would recommend price-wise? A quick look on ebay says about £90
Thanks guys
Jennie
Awful buzzing from exhaust
KP
- x 27
£90 isn't bad for a cat section. Best to get the old one off and wiegh it in as well as they fetch a few quid for the metals inside them
Having had a quick look under mine the other day i'd imagine it a bit of a pig to do the job at the turbo end but plenty of daily soaking with WD40 should help it when the time comes along
Jennie
- x 8441
Jennie,
Check the front of the cat is not catching on the subframe. It quite often the problem, especially if the mid-section has been replaced and not absolutely correctly aligned. There's not a lot of clearance.
If this is a problem, you'll see fret marks on the cat body where it's been in contact.
Jennie
Quackers
- x 17
Brigsygtt
Bafflepipe might be rattling in the centre box/rear box. Seems to happen on all non genuine exhausts after a few miles.
If the cat is gone it will make a tinny noise, smash the guts out of it.
97 Xantia 1.9 td lx with a/c (Daily, 172K, FOR SALE)
98 Xantia Hdi Lx with a/c (105k)
97 Renault Extra (c1j turbo 230+hp, 12.88@106)
91 Renault 5 Gt turbo (68k minter)
