Awful buzzing from exhaust
Jennie
Unread post by Jennie »
Hiya all, I think my cat has gone. Originally it was thought that the back box was catching the bumper but after a shuffle it was still making the horrible vibrating noise at about 2000 revs, it sounds like the cat
Preferably i would like it replaced by Fri for ace cafe, but if not im sure another few days wont hurt? Has anyone got anywhere they would recommend price-wise? A quick look on ebay says about £90
Thanks guys
Jennie
KP
x 27
Unread post by KP »
£90 isn't bad for a cat section. Best to get the old one off and wiegh it in as well as they fetch a few quid for the metals inside them :)
Having had a quick look under mine the other day i'd imagine it a bit of a pig to do the job at the turbo end but plenty of daily soaking with WD40 should help it when the time comes along :)
Jennie
Thanks for the wd40 tip, i will make sure that gets done. The section from the cat to the back box is only a year old so that end shouldnt be a problem
Im going to have to turn my music up for the 500 mile journey this weekend :lol:
x 8334
Jennie,
Check the front of the cat is not catching on the subframe. It quite often the problem, especially if the mid-section has been replaced and not absolutely correctly aligned. There's not a lot of clearance.
If this is a problem, you'll see fret marks on the cat body where it's been in contact.
Jennie
A glimmer of hope! Im hoping it is as simple as that but not holding out too much hope as it has been checked whilst i revved it over a pit, but its worth a look, thanks
Quackers
x 17
Unread post by Quackers »
I just got this annoying rattle at just over 2000rpm fixed, it was the top engine mount, maybe yours is the same annoying rattle.
Brigsygtt
Unread post by Brigsygtt »
Bafflepipe might be rattling in the centre box/rear box. Seems to happen on all non genuine exhausts after a few miles.
If the cat is gone it will make a tinny noise, smash the guts out of it.
97 Xantia 1.9 td lx with a/c (Daily, 172K, FOR SALE)
98 Xantia Hdi Lx with a/c (105k)
97 Renault Extra (c1j turbo 230+hp, 12.88@106)
91 Renault 5 Gt turbo (68k minter)
