Loudish droning noise coming from Xantia 1.9td
Barbarian
I seem to have a droneing sound comeing from my xantia TD above 30mph, Im not sure if this sound has always been their or not but its starting to bug me so i guessing not. Its not coming from the engine because if press the clutch and coast along letting the engine revs fall to idle speed the drone is still their. Any ideas?
f00lzz
Barbarian
fastandfurryous
- x 4
- x 1238
- x 1431
"if it is a wheel bearing, the noise will get louder when the weight is thrown on to the side with the faulty one."
Since this a Xantia, not always! I had one go that I was convinced was the N/S/F, based on the above. But when I took it to the gargae, it turned out to be the O/S/F - ie it went quiet when loaded.
Got to love these Xantias 8) Incidentally that was only noisy above 30 mph, but I agree, if there's no change when going round bends, then t's probably the O/S driveshaft bearing.
- x 1238
Barbarian
I dunno the noise seems to come and go, I did'nt notice it at all this morining on my way to work, yet last night on my way home from work it seemed quite loud, Maybe its just the general droneing from the car? if it s the O/S driveshaft bearing what would happen if i left it unrepaired for a good while?
Kowalski
- x 1238
DomClarke
Mandrake
- x 694
There is good sense in this..... in my experience with droning wheel bearings its very hard to identify for certain which wheel it is!DomClarke wrote:If it is the wheel bearing your best replacing both sides anyway, as if one as gone the other usually isn't far behind!
Dom
It's so easy to be confident which one it is, replace it, and find out you were wrong and still have the problem....
Regards,
Simon
Simon
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
1977 G Special 1129cc LHD
1978 CX 2400
Barbarian
fastandfurryous
- x 4
it will get louder and louder until it becomes a continuous grinding noise while the car is moving. It will also become visually obvious if you get under the car and have a look at the bearing.Barbarian wrote: if it s the O/S driveshaft bearing what would happen if i left it unrepaired for a good while?
This is not a signature.
AndersDK
