Loudish droning noise coming from Xantia 1.9td
Barbarian
Unread post by Barbarian »
I seem to have a droneing sound comeing from my xantia TD above 30mph, Im not sure if this sound has always been their or not but its starting to bug me so i guessing not. Its not coming from the engine because if press the clutch and coast along letting the engine revs fall to idle speed the drone is still their. Any ideas?
f00lzz
Unread post by f00lzz »
Wheel Bearing?
Ian
Account Ref: 6419
Current Cars
Nissan X-Trail SVE
Saab 2.2TiD
Merc E270 Estate
Past Citroens
2001 Xantia 3.0 Exclusive
1999 Xantia 1.9TD
1997 Xantia 3.0 Exclusive
1995 XM 3.0 Exclusive Estate
Barbarian
iv no idea it does not seem to affect the driving of the car, just seems to occur above 30, how much would it br for small garage to fix the wheel bearing?
fastandfurryous
x 4
Unread post by fastandfurryous »
Driveshaft bearing.
Especially if steering/braking don't change the noise.
The bearing is cheap, but the driveshaft has to come out to change it. I'd guess it's an hour's work for a decent garage.
This is not a signature.
x 1238
Unread post by Peter.N. »
Wheel bearing is favourite, try cornering one way and then the other while listening, if it is a wheel bearing, the noise will get louder when the weight is thrown on to the side with the faulty one.
x 1435
"if it is a wheel bearing, the noise will get louder when the weight is thrown on to the side with the faulty one."
Since this a Xantia, not always! I had one go that I was convinced was the N/S/F, based on the above. But when I took it to the gargae, it turned out to be the O/S/F - ie it went quiet when loaded. :twisted: Got to love these Xantias 8) Incidentally that was only noisy above 30 mph, but I agree, if there's no change when going round bends, then t's probably the O/S driveshaft bearing.
x 1238
Ah well, theres allways an exception to the rule.......especially when its one of mine! :cry:
Barbarian
I dunno the noise seems to come and go, I did'nt notice it at all this morining on my way to work, yet last night on my way home from work it seemed quite loud, Maybe its just the general droneing from the car? if it s the O/S driveshaft bearing what would happen if i left it unrepaired for a good while?
Kowalski
Unread post by Kowalski »
Peter.N. wrote:Ah well, theres allways an exception to the rule.......especially when its one of mine! :cry:
Two exceptions to the rule!
My Xantia did the same thing, wheel bearing got quieter with load.
x 1238
The o/s driveshaft bearing failed on my XM and resulted in comlete lack of drive, It allowed the shaft to slide out of the diff! But I think that is probably exeptional.
DomClarke
Unread post by DomClarke »
If it is the wheel bearing your best replacing both sides anyway, as if one as gone the other usually isn't far behind!
Dom
x 694
Unread post by Mandrake »
DomClarke wrote:If it is the wheel bearing your best replacing both sides anyway, as if one as gone the other usually isn't far behind!
Dom
There is good sense in this..... in my experience with droning wheel bearings its very hard to identify for certain which wheel it is!
It's so easy to be confident which one it is, replace it, and find out you were wrong and still have the problem.... :oops:
Regards,
Barbarian
If its not a big issue ill just leave it for while!
fastandfurryous
x 4
Barbarian wrote: if it s the O/S driveshaft bearing what would happen if i left it unrepaired for a good while?
it will get louder and louder until it becomes a continuous grinding noise while the car is moving. It will also become visually obvious if you get under the car and have a look at the bearing.
AndersDK
Unread post by AndersDK »
The noise alone will eventually become un-bear-able during drive :roll:
Anders (DK) - '90 BX16Image
