[RT6 RNEG2] Request for software / firmware
This unit is the eMyWay system, also referred to as RT6, RNEG2, or WIPNAV+ for the Peugeot platform and made by Magneti Marelli.
Main Features: The eMyWay colour satellite navigation has high resolution mapping, Bluetooth Telephone & Audio Streaming supported profiles, USB support for Media files & CD
kevin508
Re: [RT6 RNEG2] Request for software / firmware
Unread post by kevin508 »
Hello Paul,
I would like to explain my situation in a little more detail.
My original internal 8 GB microSD card was failing. I managed to create a sector-by-sector image, but there were a few unreadable sectors during the recovery process.
I restored this image onto a new Kingston Industrial microSD card.
We carefully checked the image:
all three partitions are present,
the navigation files appear to be complete,
the image looks almost identical to the original SD card,
however, we cannot be certain that the unreadable sectors did not contain critical boot data.
Since replacing the SD card, the RT6 powers on, the screen is backlit but remains completely black (no Peugeot logo), and the CD drive keeps trying to read the firmware disc for several minutes before ejecting it.
Do you think that a few missing sectors on the original SD card could be enough to prevent the RT6 from booting completely?
If so, would it be possible to obtain a known-good RT6/RNEG2 SD card image for comparison, or would you recommend another recovery method?
I also have the official RT6 firmware 2.86 CD (part number 9691894880), and I will try the USB installation as you recommended.
I am happy to perform any additional tests you may suggest.
Thank you very much for your time and expertise.
J'ai juste ajouté une phrase à la fin :
"I am happy to perform any additional tests you may suggest."
(Je suis prêt à effectuer tous les tests supplémentaires que vous pourriez me conseiller.)
x 1938
Unread post by Paul-R »
It's not really possible to find a car that's exactly the same as one's own. The next step would be to try updating from a USB stick. If you're using a computer to copy from the CD then you have to copy the contents of the CD to the stick, not the ISO image of the CD.
A thought that occurs to me is that the SD card might interrupt the booting process with being partially cloned already. If that occurs then my next step would be to use a partition manager to clear the card and then format it with Fat 32.
kevin508
Hello Paul,
Thank you very much for your advice.
I will prepare a USB stick correctly by copying the extracted contents of the firmware CD (not the ISO file) and test it as you suggested.
I also understand your point about the SD card. If the USB update still does not start, I will completely erase the replacement SD card, repartition and format it to FAT32 before trying again.
Thank you again for taking the time to help me.
Best regards,
Kevin
MojoTheJester
New User
Unread post by MojoTheJester »
Hi, I've finally got my rt6 out of bootloop and working, running 2.86b. However, the parking sensors are not working. Apparently I should be looking in datexplorer for blocks 1.1 or 1.2 in the user config dat file, but my blocks start at 1.3. Apparantly I need the base rt6_286 config file rather than the rt6_2xx config file in datexplorer, but I can't find 286
x 1938
Sorry, I can't help with this except to say that I would have thought Mirascript could activate this option.
kevin508
Hi Paul,
I have some new test results since my last post.
I prepared a new 16 GB PNY SD card using the official SD Card Formatter (Overwrite Format) and left it blank, as previously suggested. I then inserted it into the RT6 and booted with the extracted 2.86 firmware on a FAT32 USB stick.
Unfortunately, the behaviour is unchanged.
The RT6 powers up, accesses the USB stick, then powers off. The USB stick loses power, I hear the CD mechanism initialise, the RT6 powers up again, the USB stick is read again, and this cycle repeats continuously (more than six times). There is still no Peugeot logo and no firmware update screen.
The same behaviour occurred with my cloned SD card.
Do you have any further suggestions on what to check next? Could this indicate a bootloader or hardware issue rather than the SD card itself?
Thank you again for your help
x 1938
I think it's a hardware issue as you probably suspected. There are companies that can repair these units and there have been posts here about them. I will try to find them, tomorrow now I'm afraid.
kevin508
Hi Paul,
Thank you for your reply.
I would like to clarify one important point because it may change the diagnosis.
My original SD card still boots the RT6 normally. I get the Peugeot logo, the radio, navigation and menus all work. However, the unit still has the original faults which is why I started replacing the SD card.
The continuous reboot problem only occurs with the cloned SD card and with a newly formatted 16 GB PNY card (formatted with the official SD Card Formatter and tested with the extracted 2.86 firmware on USB).
Does this information change your opinion? Could this still be an SD card / cloning issue rather than a hardware fault?
Thank you again for your help.
kevin508
Hi Paul,
I have some new information which may change the diagnosis.
With the original SD card, the RT6 still boots normally. It shows the Peugeot logo, starts completely, and the radio, navigation and menus all work. However, it still has the original faults that made me suspect the SD card in the first place (incorrect date, occasional issues, etc.).
Today I inserted the firmware USB while the RT6 was running with the original SD card. The unit detected the update media, but after checking it displayed the message:
“Support de mise à jour endommagé ou incomplet” (“Update media damaged or incomplete”).
With both my cloned SD card and a brand new 16 GB PNY SD card (formatted using the official SD Card Formatter with Overwrite Format), the RT6 never reaches the Peugeot logo. It simply enters a continuous reboot loop while repeatedly reading the USB stick.
Because the original SD card still boots the unit, do you think this still points to a hardware fault?
Is it possible that my 2.86 firmware package is incomplete or corrupted?
Would you happen to have a known good RT6 (RNEG2) 2.86 firmware package, or another version that you know is genuine and working?
Thank you very much for your time and help
x 1938
I'm beginning to run out of ideas here. I can't remember If you already had the 2.86 firmware update yourself or if I supplied it but I will PM you links for this as both an ISO and for directly copying onto a USB stick - although I think they are both the same.
Apart from that I'm just not sure. Maybe the RT6 unit is failing elsewhere. I shall add you to list of people that I have said I will give details of companies that can repair these units.
x 1938
This post gives information about a company in Romania that repairs these units.
viewtopic.php?p=870835#p870835
EDIT
I have no personal recommendations but here are three results from a quick search of the internet.
https://www.lesevans.co.uk/
http://revivecaraudio.co.uk/read-more/
http://www.rwer.co.uk/services_carradiorepairs.htm
mikelee1983
Unread post by mikelee1983 »
Hello, i have a 2013 CitroenDS5 with a Magneti Marelli RNEG2 (eMyWay/RT6) unit, part number 9806709180. The internal microSD card has failed and i've replaced it with a new blank 32GB card formatted as FAT32. Could someone please provide the correct RT6/RNEG2 firmware 2.86B( 9691894880) and advise on rebuilding the internal SD card? Thankyou
kevin508
I had the same issue with my RT6. If someone here already has the official RT6 firmware CD (v2.86B), they may be able to share it with you. Otherwise, you can buy the official firmware CD for around €13, which is what I recommend.
Once you have it, install a compatible microSD card and let the RT6 rebuild the system. After that, you can install the latest maps.
Good luck!
x 1938
Check your PM in a few minutes for links to 2,86. I can't guarantee it being version 'B' though.
No liabilities. Use at own risk, etc.
The best I can do for advice on how to rebuild the card is to direct you to this thread viewtopic.php?p=868804#p868804
This is the last page of a very long thread, If what's written there doesn't help then maybe you'll need to read it from the start,
