206cc to a 308cc How ? Why ? Everything 308cc
x 8156
Re: 206cc to a 308cc How ? Why ? Everything 308cc
I would assume one of two things has happened there Husky, either the new version is manufactured from stronger material or they realised that the original had been over engineered and so reduced the diameter to make savings! I'd fit it as it has the same OEM number and if it does go awry you will have a claim. :)
Huskyxantia
x 928
Unread post by Huskyxantia »
Maybe the over engineered design has caused it to fail?
:-D
x 2367
Unread post by MattBLancs »
Huskyxantia wrote: 03 Sep 2026, 07:26 My only niggle is the longest part of my original drive shaft is thick , the new one is thinner BUT it definitely comes up with the matching oem
When I changed my 306's driveshafts the originals (tubular) were much thicker than the replacements (J&R Driveshafts - just a solid bar)
If the splines and length are a match, I'd get it fitted. Am sure it'll be fine.
Tubular driveshaft was intended to reduce its weight, supposed to minimise torque steer I believe??? I couldn't tell any appreciable difference.
x 2367
Actually the long bit has the intermediate bearing, I don't think the outside diameter of that bearing varies but that'd be another key dimension to check :)
Huskyxantia
x 928
They look the same , ive not done it yet waiting drive shaft oil seal , or gear box lip seal or what ever else its called now from over 30 years ago lol. Also recalled when did a replacement on my zx estate that one wasn't as thick , same length aswell it drove fine after fitted too.
:-D
Huskyxantia
x 928
MattBLancs wrote: 04 Sep 2026, 07:27 Actually the long bit has the intermediate bearing, I don't think the outside diameter of that bearing varies but that'd be another key dimension to check :)
Bearing looks same
:-D
Huskyxantia
x 928
mickthemaverick wrote: 03 Sep 2026, 07:57 I would assume one of two things has happened there Husky, either the new version is manufactured from stronger material or they realised that the original had been over engineered and so reduced the diameter to make savings! I'd fit it as it has the same OEM number and if it does go awry you will have a claim. :)
Good idea i have a back up if it goes wrong. I can make a claim . Plus I was offered 30 day to return if its no good so still got plenty of days left
:-D
ozfrog
(Donor 2026)
x 84
Unread post by ozfrog »
Huskyxantia wrote: 04 Sep 2026, 08:37 Good idea i have a back up if it goes wrong. I can make a claim . Plus I was offered 30 day to return if its no good so still got plenty of days left
I’m sure they don’t mean that you can fit the part and use it in the car for a few days and then decide that you don’t want to keep it!
I’m sure they mean that they want it back to them in saleable condition, that is, the same condition that you received it in.
Cheers,
Andrew
Huskyxantia
x 928
ozfrog wrote: 04 Sep 2026, 13:49
Ive spoken to a handler the other day they said if i place it in the carefully and it fits then that's a keeper, however if it happens to be to short in length by pulling the hub carrier amd front leg to far in then it can go back , ive just got to be careful when doing the task , but offering it up for comparison to the old one length was the same, plus weight aswell . I should be ok
:-D
Huskyxantia
x 928
Arrived home earlier today and the seals have arrived, nice , pity now though ive not good light to do the job plus its drizzling aswell . There's always the weekend.
Nice new seals
Nice new seals
:-D
Huskyxantia
x 928
Rp0thejester wrote: 01 Sep 2026, 20:57 Online Automotive is worth a go.
These guys gave me the correct oem numbers for both sides, thank you for dropping there name down here for me .
:-D
x 1083
Unread post by Rp0thejester »
I'm surprised you emailed them for the part numbers, better safe than sorry I suppose. I prefer to just use their website with my car reg and they find everything that fits. I did have 1 issue with springs as the system included a Chevy Corvette C8 front springs. They emailed me the next day saying they were wrong for my car, which shows good knowledge on their part and still sent what I needed before the bank holiday weekend. Plus no faffing in sending something back that wasn't correct.
Huskyxantia
x 928
Rp0thejester wrote: 04 Sep 2026, 19:57 I'm surprised you emailed them for the part numbers, better safe than sorry I suppose. I prefer to just use their website with my car reg and they find everything that fits. I did have 1 issue with springs as the system included a Chevy Corvette C8 front springs. They emailed me the next day saying they were wrong for my car, which shows good knowledge on their part and still sent what I needed before the bank holiday weekend. Plus no faffing in sending something back that wasn't correct.
All fairness they were fast getting back to me next time I need anything im going to try there website, just the time I had was very much taken up with family stuff .... but ... next time , ive book marked the site, oh god I sound like a right geek lol
:-D
Huskyxantia
x 928
MattBLancs wrote: 31 Aug 2026, 08:47
Huskyxantia wrote: 30 Aug 2026, 14:43 So new ball joint is in 90nm toqure setting hub
Just checking: this isn't the torque setting you've installed that big 41mm ball joint into the hub at is it?
Haynes 308 figures for you:
Think this didn't like 325nm
:-D
Huskyxantia
x 928
These are crusty so they got a wire wheel treatment with the cordless drill then rust proofed afterward driver side is all done .
Cleaned the caliper housing and rust treated
:-D
