206cc to a 308cc How ? Why ? Everything 308cc
- x 2356
Re: 206cc to a 308cc How ? Why ? Everything 308cc
Ok!? Looks bloody fantastic that!
Huskyxantia
- x 917
Your very kind sir , cheques in the post
Husky.
- x 8411
It certainly does
Huskyxantia
- x 917
Ok so think i mentioned I was having problems getting the roof to behave so today was the day I had been waiting for . I had to do the liner again the black liner was to thick..... 1.2mm to be exact.
Last week I did find a nice grey light velvet colour with foam backing and got another can of spray glue gunky messy stuff, so manual roof thing again then liner board out , new cloth on ... oh my it looks ok this one ... then fitted it all back manually closed the roof .... moment of truth button time and bingo roof opened , push again roof closed ... who would of though that the thickness of the liner would of cause so much bother .
Photos soon.
Photos soon.
Husky.
- x 8129
The thickness of liners has been a consistent concern since 1912
Huskyxantia
- x 917
"Haha, the battle with headliner tolerances is clearly timeless! Glad to report the thinner fabric did the trick—roof is opening and closing perfectly now with no binding."
Some photos of the new brushed velvet type of cloth , feels so nice its worth the touch to mess it's pile up lol
Husky.
Huskyxantia
- x 917
There we go, anyone wanting to under take this headliner replacement/renewal... don't go to thick.
Husky.
Huskyxantia
- x 917
On a plus side the seller has offered me a refund due to the problem caused with the roof , win win amd thanks
Husky.
- x 8411
That did make me giggle Mickmickthemaverick wrote: 23 Aug 2026, 18:19 The thickness of liners has been a consistent concern since 1912![]()
Huskyxantia
- x 917
Running a session with my autel maxicom 808s
So my dpf according to the diagnostic machine isn't full, blocked or looking like it needs a regen..
So this may well be a sensor that's dirty, packing up the ghost and throwing a tantrum when it feels like it , also while opening the car i noticed my front off side tyre..... see photos of my jabber jabber
- Attachments
Husky.
Huskyxantia
- x 917
So the saved faults are , then I wiped them , re scanned and its all clear ... ive got some thinking to do about this car.
Do I use it enough
Do u need to keep on top of more than one car especially when im not to good or other stuff happens.
Should I part ex this for something smaller
I Don't know......
Do I use it enough
I Don't know......
Husky.
Huskyxantia
- x 917
So ive still got the new o rings to fit on the leak off pipe clips , I did purchase a new inner and out steering tie rod set plus a lower ball joint aswell , for both sides. If I do part with the car these can go with it , im still doing the o rings.
Husky.
Huskyxantia
- x 917
Anyone know what causes this time happen to these little disc screws
Husky.
Huskyxantia
- x 917
Lower balkjojnt naff , 41mm deep socket to the rescue
Husky.
Huskyxantia
- x 917
2 months ago there was a slight vibration at around 45 to 60 mph , so free time today at last and dry weather ive ruled out the upper tier rod inner and outer they are fine they are tight and hardly no play the drive shaft is the culprit should of know shouldn't i.... so one is on order ive renewed the lower ball joint , which I was dreading only due to hearing nightmares about there removal, I need not of worried it came out easy new febi brand now in place which has a 10 yr warranty, no bad is it !
Husky.
