x 6950
Re: Citroen and Peugeot Parts Requests
Chris, PM Sent.
x 6950
Chris, do you have the VIN for the C3 please? Pop it up here and and I'll take a look.
dan g
(Donor 2021)
Unread post by dan g »
I wish to change front shock absorbers and top mounts on my 5008 vin: VF3**************[VIN obfuscated, can be read by forum staff]
Can i have the part no for.these and top mount assembly illustration please.
x 6950
Re: Citroen and Peugeot Official Parts Requests
dan g wrote: 22 Feb 2022, 22:19 I wish to change front shock absorbers and top mounts on my 5008 vin: VF3**************[VIN obfuscated, can be read by forum staff]
Here you go Dan
Pair - Left & Right
OEM
Item (1)
9807734180 £105.91
9807734280 £105.91
Cheaper PSA Alternative:
(Left) 1635531780 £81.12
(Right) 1635530980 £81.12
Strut Boot:
Item (2), Part: 525431, £14.03
dan g
(Donor 2021)
Thank you Marc
Any info on the top strut mount/bearing ?
x 6950
Let me know what parts of the spring assembly and bump stop you need (if any):
c.morewood
x 55
Unread post by c.morewood »
GiveMeABreak wrote: 21 Feb 2022, 21:18 Chris, do you have the VIN for the C3 please? Pop it up here and and I'll take a look.
Hi Marc,
Its
Tesla Model 3 LR DM AWD Blue White
'00 Xant 110HdiSX Est 83K "W"
'99 Xant 110HdiSX Est 320K "V"
'98 Xant 1.9TDSX Est 150K "T"
'97 Xant 1.9TD 20k Est
'94 Fiat TipoTd 40K
'85 BMW K100RT 330K Garaged 26yrs '80 Honda CB250 twin Superdream
x 6950
@ Chris:
c.morewood wrote: 21 Feb 2022, 15:31 Citroen C3 Symphony 2008 1.3Hdi
Hi looking for the gearbox bracket part no. and diagram. Its the one which carries the gear cables has 2 bolts and is located next to the starter motor ( starter motor in foreground in photo)
I've inherited this car and the bracket has broken and is held together by a cable tie. Also part no and diagram for the suspension top bearing as that appears to have seized as well.
Ok so this is a 1.4 HDi Chris, there's no 1.3 engines on these.
I'm putting up the 2 Gearbos diagrams, the first being the Gearshift fixing bracket and the second are the spindles and forks. Let me know which item numbers you want by referencing the table A or B and the item number. The last table 'C' is for the suspension mounts - again let me know the items you want part numbers for by prefacing with Table C.
Table ATable BTable C
c.morewood
x 55
Typo Marc.. big fingers.. it happens all the time, sorry.
It looks like no5 in Table A
In Table C, Is 6 or 70 a bearing? It's difficult to make out as I've not had the pleasure of taking one of those apart. The garage just said that it was the bearing that needed replacing. Its just not rotating properly at full locks and graunches dreadfully.. Shetland weather again.
'94 Fiat TipoTd 40K
x 6950
Clicking the diagrams will zoom them Chris.
Table A
Part: 243759, £33.54
Table C
(6) Is the Front Bump Stop Cup, Part: 503374, £13.60
(70) is the Base Nut, Part 503623, £1.57
However t here is a kit, item (11) that includes (2, 3, 9 & 70),
OEM, Part: 503196, £51.94
Cheaper alternative, Part: 1638380780, £35.17
jamescarruthers
x 47
Unread post by jamescarruthers »
Hello,
Would someone please be able to confirm the starter motor that I need for my 2001 Citroen C5 2.2. I believe it requires the higher power rated one (2.2kW). Are there different numbers of teeth that I need to be aware of?
1987 Volvo 480 ES
2006 Citroen C6 3.0 petrol Exclusive
x 6950
@ James
Your original starter was a Valeo, D 8 R 27, Class 6+
OEM New, Part: 5802Z5, £585.48
Exchange Starter, Part: 5802EF, £274.19
(Note there is a refundable surcharge of £78.12) on these.
jamescarruthers
x 47
GiveMeABreak wrote: 23 Feb 2022, 19:00 @ James
Much appreciated!
1987 Volvo 480 ES
c.morewood
x 55
GiveMeABreak wrote: 23 Feb 2022, 18:46 Clicking the diagrams will zoom them Chris.
Table A
Table C
Thanks Marc.. that helps a lot.
'94 Fiat TipoTd 40K
dan g
(Donor 2021)
GiveMeABreak wrote: 23 Feb 2022, 14:15 Let me know what parts of the spring assembly and bump stop you need (if any):
Thanks Marc
Item 9 bearing part number please
Are the OEM number listed above for the shock absorbers newer revision numbers.?
Some parts websites are listing shorter oem references as a match for this model.
