- GiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
GS 1000 Cedreat Yellow - x 5739
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
Re: Citroen and Peugeot Parts Requests
Chris, do you have the VIN for the C3 please? Pop it up here and and I'll take a look.
- (Donor 2021)
- My Cars: c4 1.6hdi 2008
I wish to change front shock absorbers and top mounts on my 5008 vin: VF3**************[VIN obfuscated, can be read by forum staff]
Can i have the part no for.these and top mount assembly illustration please.
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
Re: Citroen and Peugeot Official Parts Requests
Here you go Dan
Pair - Left & Right
OEM
Item (1)
9807734180 £105.91
9807734280 £105.91
Cheaper PSA Alternative:
(Left) 1635531780 £81.12
(Right) 1635530980 £81.12
Strut Boot:
Item (2), Part: 525431, £14.03
- (Donor 2021)
Thank you Marc
Any info on the top strut mount/bearing ?
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
Let me know what parts of the spring assembly and bump stop you need (if any):
- Donor 2023
- My Cars: '00 Xantia 110 bhp Hdi SX Estate 65K "W"
'99 Xantia 110 bhp Hdi SX Estate 310K SORN "V"
'98 Xantia 1.9TD SX Estate 150K Sold "T" - x 47
Hi Marc,GiveMeABreak wrote: ↑21 Feb 2022, 21:18 Chris, do you have the VIN for the C3 please? Pop it up here and and I'll take a look.
Its
'00 Xant 110HdiSX Est 83K "W"
'98 Xant 1.9TDSX Est 150K "T"
'97 Xant 1.9TD 20k Est
'94 Fiat TipoTd 40K
'94 Fiat TipoTd 40K
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
@ Chris:
I'm putting up the 2 Gearbos diagrams, the first being the Gearshift fixing bracket and the second are the spindles and forks. Let me know which item numbers you want by referencing the table A or B and the item number. The last table 'C' is for the suspension mounts - again let me know the items you want part numbers for by prefacing with Table C.
Ok so this is a 1.4 HDi Chris, there's no 1.3 engines on these.c.morewood wrote: ↑21 Feb 2022, 15:31 Citroen C3 Symphony 2008 1.3Hdi
Hi looking for the gearbox bracket part no. and diagram. Its the one which carries the gear cables has 2 bolts and is located next to the starter motor ( starter motor in foreground in photo)
I've inherited this car and the bracket has broken and is held together by a cable tie. Also part no and diagram for the suspension top bearing as that appears to have seized as well.
Table A | Table B | Table C |
- Donor 2023
Typo Marc.. big fingers.. it happens all the time, sorry.
It looks like no5 in Table A
In Table C, Is 6 or 70 a bearing? It's difficult to make out as I've not had the pleasure of taking one of those apart. The garage just said that it was the bearing that needed replacing. Its just not rotating properly at full locks and graunches dreadfully.. Shetland weather again.
'94 Fiat TipoTd 40K
'94 Fiat TipoTd 40K
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
Clicking the diagrams will zoom them Chris.
Table A
Part: 243759, £33.54
Table C
(6) Is the Front Bump Stop Cup, Part: 503374, £13.60
(70) is the Base Nut, Part 503623, £1.57
However t here is a kit, item (11) that includes (2, 3, 9 & 70),
OEM, Part: 503196, £51.94
Cheaper alternative, Part: 1638380780, £35.17
Table A
Table C
- Donor 2023
- My Cars: 1987 Volvo 480 ES
2006 Citroen C6 3.0 petrol Exclusive - x 48
Hello,
Would someone please be able to confirm the starter motor that I need for my 2001 Citroen C5 2.2. I believe it requires the higher power rated one (2.2kW). Are there different numbers of teeth that I need to be aware of?
1987 Volvo 480 ES
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
@ James
Your original starter was a Valeo, D 8 R 27, Class 6+
OEM New, Part: 5802Z5, £585.48
Exchange Starter, Part: 5802EF, £274.19
(Note there is a refundable surcharge of £78.12) on these.
- Donor 2023
Much appreciated!GiveMeABreak wrote: ↑23 Feb 2022, 19:00 @ James
1987 Volvo 480 ES
- Donor 2023
Thanks Marc.. that helps a lot.GiveMeABreak wrote: ↑23 Feb 2022, 18:46 Clicking the diagrams will zoom them Chris.
Table A
Table C
'94 Fiat TipoTd 40K
'94 Fiat TipoTd 40K
- (Donor 2021)
Thanks MarcGiveMeABreak wrote: ↑23 Feb 2022, 14:15 Let me know what parts of the spring assembly and bump stop you need (if any):
Item 9 bearing part number please
Are the OEM number listed above for the shock absorbers newer revision numbers.?
Some parts websites are listing shorter oem references as a match for this model.
