2016 C4 Picasso Abs, esp, parking brake and tyre inflation monitor faults showing
x 6945
Re: 2016 C4 Picasso Abs, esp, parking brake and tyre inflation monitor faults showing
Here you go:
7825 is the rear right Wheel Sensor.
7800 is the ESP ECU
7032 is the Right Hand Rear Wheel Speed Signal Reference on Pin 1 going to Pin 37 of the ECU via the harness interconnections.
7031 Right Hand Rear Wheel Speed Signal on Pin 2 going to pin 22 of the ECU via the harness interconnections.
These go back to the ESP ECU via the 80 AR SP main harness and the ICK5D interconnection.
Main Wiring Diagram
Close up of Rear Right Wheel Sensor
Wiring Harness 80 AR SP
The wheel sensor wiring then connects with ICK5D under the rear seats as shown:
Here is the 4 pin ICK5D connector showing the wheel speed sensor pins in the interconnection: It should be a black 4 pin connector (not 6 pin as shown on the diagram - but can't be sure - you know the French!)
tomaskriv
(Donor 2026)
x 6
Unread post by tomaskriv »
Thanks.
tomaskriv
(Donor 2026)
x 6
Will try to get my hands there as soon as possible. When ignition on, should I see any voltage on abs sensor pins? Or sensor sends signal to the ecu?
x 6945
There are 2 types of rear wheel speed sensor according to options (semi automatic parking) but pin 1 contains the sensor supply and pin 2 contains the data stream.
tomaskriv
(Donor 2026)
x 6
Will check at the sensor if I have anything on pin1. If not then will check under the seat connection.
Just hope it will be easy to gain access to that connector..
tomaskriv
(Donor 2026)
x 6
Marc,
Stupid question:
Ive removed front left wheelarch. Cant see abs unit... Where is this ting located?
x 6945
That's because it's not under the front left wheel arch - it's under the front right wheel arch on this model. :-D
tomaskriv
(Donor 2026)
x 6
OK. Thank you. Checked wires from rear sensor as far as I was able to reach. Looks Ok. Next step to disconnect them from ABS unit and check with multimeter.
tomaskriv
(Donor 2026)
x 6
Fron right wheel arch removed. No pump...Well I do have idea what to look for. Cant see it here.....
x 6945
There's a guide I've put up in the member's resources section Tomas:
C4 Picasso MK II (B78) ABS / ESP Module Removal - Refitting
tomaskriv
(Donor 2026)
x 6
Sorry but I am not authorised to see this forum...
x 6945
Access to information in the Resources Section and live PSA parts info requests require members to have made a contribution to the Forum Tomas. Details below:
A response to your question by a Forum Admin requiring parts or additional information requires you to have made a current contribution (£10 min.) to the Forum.
To Upgrade Your Membership & Donate Click Here
For Further Information About Vehicle Parts and VIN Numbers Click Here
tomaskriv
(Donor 2026)
x 6
Case closed.
Checked continuity from connector under the seat to sensor - yellow wire dead. One new wire later all good now.
Thank you Marc for wiring diagram and harnes location.
Now only aditive reset left and car will be trouble free.
x 6945
You are welcome, well done on sticking with it. The wiring on these vehicles is legendary!
garddian
Unread post by garddian »
Hi GiveMeABreak, I dont suppose you have a legend for the other items on this Main Wiring Diagram please.
