PSA NAC RCC Updates
emircanakisci
Re: PSA NAC RCC Updates
Hello Marc,
I updated the navigation and system confirms that update have been successfully made BUT when I touch the navigation section it says “ there is no map or update is still ongoing”
Do you know how to fix it or should I update it again?
- x 6955
Check the system to see what version of firmware is showing as installed.
If it is correct. then you need to install your maps as per the link, but make sure you have fully formatted the USB again and that it is large enough to hold the map update.
- x 6955
eevrenci
I tried it with many flash drives but it didn't work, it always restarted at 37%. Then I prepared the flash memory from another computer, finally it was successful. The problem was a memory error on the first computer I tried.GiveMeABreak wrote: 07 Mar 2024, 19:16 No mistake my end. Files are as they were provided, but it may be your internet connection where you are. Links again below:
Firmware v6_0422_23.3I37.1
eevrenci Licence File
Thanks for your help Marc.
- x 6955
Ok, no problem.
Gerry odonnell
Hi l, may I have a link too please?
I am also getting the error message when trying to download the update.
My vin is VF7**************[VIN obfuscated, can be read by forum staff]
E Dispatch 75KW
E Dispatch 75KW
emircanakisci
Hello Marc,
Thank you so much, I managed to update multimedia.
Now my friend also need your support, could you please share links for the update of the below VIN?
VIN: VR3**************[VIN obfuscated, can be read by forum staff]
Thanks in advance!
Thanks in advance!
- x 6955
6_0422_23.3I37.1 FirmwareGerry odonnell wrote: 10 Mar 2024, 12:09 Hi l, may I have a link too please?
E Dispatch 75KW
Gerry odonnell Licence File
Updating NAC or RCC Firmware, Maps, Licences
- x 6955
44.07.05.22_NAC-r0 Firmwareemircanakisci wrote: 10 Mar 2024, 12:43 Hello Marc,
Thanks in advance!
Licence File
Map V15
bass180
Hello,
I have the same update problem. I can't download the file
I may need the update file and the licence file
- x 6955
and1
Thanks Marc!
Update takes 15 minutes then stops at 50% for a longer time and then continues quickly.
Caqui
Hello, you do a great job.
Can you please help me and provide me the latest update and licence key?
I have problems to get from the Citroen software.
VIN: VR7**************[VIN obfuscated, can be read by forum staff]
Thanks a lot!
Thanks a lot!
- x 6955
Dias
Hello, i need to flash my infoitment, somome try to update my system remotly to have android auto & carplay but now the system is stuck, with low light and no acess to side buttons of display. Can i fix it with any firmware or do i have to contact the dealership? It a Citroën c3 aircross 2019
