PSA NAC RCC Updates
This is the Connected NAV system.
Main Features: It is a fully integrated Telematics System featuring CarPlay, Android Auto, Real Time Services, Voice Commands, High-Res Display, 3D Navigation, Bluetooth Hands Free & USB. 2 versions of the system are available NAC (Navigation Audio Connectée) and RCC (Radio Couleur Connectée) or Connected Colour Radio, which does not have the Integrated Navigation or Live Services.
emircanakisci
Re: PSA NAC RCC Updates
Unread post by emircanakisci »
Hello Marc,
I updated the navigation and system confirms that update have been successfully made BUT when I touch the navigation section it says “ there is no map or update is still ongoing”
Do you know how to fix it or should I update it again?
x 6956
Check the system to see what version of firmware is showing as installed.
If it is correct. then you need to install your maps as per the link, but make sure you have fully formatted the USB again and that it is large enough to hold the map update.
x 6956
eevrenci
Unread post by eevrenci »
GiveMeABreak wrote: 07 Mar 2024, 19:16 No mistake my end. Files are as they were provided, but it may be your internet connection where you are. Links again below:
Firmware v6_0422_23.3I37.1
eevrenci Licence File
I tried it with many flash drives but it didn't work, it always restarted at 37%. Then I prepared the flash memory from another computer, finally it was successful. The problem was a memory error on the first computer I tried.
Thanks for your help Marc.
x 6956
Ok, no problem.
Gerry odonnell
Unread post by Gerry odonnell »
Hi l, may I have a link too please?
I am also getting the error message when trying to download the update.
My vin is VF7**************[VIN obfuscated, can be read by forum staff]
E Dispatch 75KW
emircanakisci
Hello Marc,
Thank you so much, I managed to update multimedia.
Now my friend also need your support, could you please share links for the update of the below VIN?
VIN: VR3**************[VIN obfuscated, can be read by forum staff]
Thanks in advance!
x 6956
Gerry odonnell wrote: 10 Mar 2024, 12:09 Hi l, may I have a link too please?
E Dispatch 75KW
6_0422_23.3I37.1 Firmware
Gerry odonnell Licence File
Updating NAC or RCC Firmware, Maps, Licences
x 6956
emircanakisci wrote: 10 Mar 2024, 12:43 Hello Marc,
Thanks in advance!
44.07.05.22_NAC-r0 Firmware
Licence File
Map V15
bass180
Unread post by bass180 »
Hello,
I have the same update problem. I can't download the file
I may need the update file and the licence file
x 6956
and1
Unread post by and1 »
Thanks Marc!
Update takes 15 minutes then stops at 50% for a longer time and then continues quickly.
Caqui
Unread post by Caqui »
Hello, you do a great job.
Can you please help me and provide me the latest update and licence key?
I have problems to get from the Citroen software.
VIN: VR7**************[VIN obfuscated, can be read by forum staff]
Thanks a lot!
x 6956
Dias
Unread post by Dias »
Hello, i need to flash my infoitment, somome try to update my system remotly to have android auto & carplay but now the system is stuck, with low light and no acess to side buttons of display. Can i fix it with any firmware or do i have to contact the dealership? It a Citroën c3 aircross 2019
