Now that would be cool JamesHell Razor5543 wrote:I wonder if it might be possible to, when the RPM hit the red line, to make the RPM gauge colour switch from green to red?
I am an Activaist-v6 and a 2.1Estateerr
- x 8204
Re: I am an Activa owner...a V6 and I am an addict
elma
- x 287
The Noble M12 GTO was the first I heard of to do it back when I was about 16.
- x 1982
A wake up wash always make you feel better....
- x 1982
Bu##er.....I have a leaking coolant expansion bottle !......it was new stock from Citroen last year
And I am not putting glue in it
Deanxm
- x 87
D
XM Prestige PRV6 92
Mitsubishi L200 Trojan 14
- x 8204
As you say Alasdair, bu**er
That one had a remarkably short life....
Time for a nice ally one then?
- x 1982
Not if I can get this switched for free Jim.....Citroen should cover it
- x 1982
Citroen are exchanging the part under warrantee. That warrantee will only run till the 12 months (from) purchase is up, eg 3 Months
- x 1982
Inside a V6 expansion tank:
- x 8204
Excellent news Alasdair... That's a lovely resultStickyfinger wrote:Citroen are exchanging the part under warrantee. That warrantee will only run till the 12 months (from) purchase is up, eg 3 Months
- x 1982
Attempting a repair......................groves cut for a gasket material/adhesive.
Holes drilled for rivets, this will not be very pretty
- x 5615
How about some plastic weld?
I've used similar stuff (A Marley product) to weld plastic water pipes together quite successfully.
- x 8204
I'm watching with great interest Alasdair
- x 1982
I have used that stuff for years now, the melted/dissolved "edges" become very brittle with this type of high carbon content plastic.myglaren wrote:How about some plastic weld?
As this is an edge to edge joint and is effected by expansion/pressurised, it will just crack apart because the layer "melted" by the solvent is very thin.
This is proven by these things always failing at the seam.
- x 5615
Shame. The pipes I have welded with it were not subject to heat or pressure - not much anyway.
I have some here that my son is hoping will repair his fairing from when he dropped his motorbike.
