x 8415
Re: I am an Activa owner...a V6 and I am an addict
Hell Razor5543 wrote:I wonder if it might be possible to, when the RPM hit the red line, to make the RPM gauge colour switch from green to red?
Now that would be cool James ;) I believe some modern ones do do something similar...
elma
x 284
Unread post by elma »
The Noble M12 GTO was the first I heard of to do it back when I was about 16.
x 1996
Unread post by Stickyfinger »
A wake up wash always make you feel better....
x 1996
Bu##er.....I have a leaking coolant expansion bottle !......it was new stock from Citroen last year :(
And I am not putting glue in it :(
Deanxm
x 87
Unread post by Deanxm »
:( not the best start to the coming summer season but hopefully the first and last problem of the year!
D
XM Prestige PRV6 92
Mitsubishi L200 Trojan 14
x 8415
As you say Alasdair, bu**er :evil:
That one had a remarkably short life....
Time for a nice ally one then?
x 1996
Not if I can get this switched for free Jim.....Citroen should cover it
x 1996
Citroen are exchanging the part under warrantee. That warrantee will only run till the 12 months (from) purchase is up, eg 3 Months :(
x 1996
Inside a V6 expansion tank:
x 8415
Stickyfinger wrote:Citroen are exchanging the part under warrantee. That warrantee will only run till the 12 months (from) purchase is up, eg 3 Months :(
Excellent news Alasdair... That's a lovely result =D>
x 1996
Attempting a repair......................groves cut for a gasket material/adhesive.
Holes drilled for rivets, this will not be very pretty :)
x 5672
How about some plastic weld?
I've used similar stuff (A Marley product) to weld plastic water pipes together quite successfully.
x 8415
I'm watching with great interest Alasdair ;)
x 1996
myglaren wrote:How about some plastic weld?
I have used that stuff for years now, the melted/dissolved "edges" become very brittle with this type of high carbon content plastic.
As this is an edge to edge joint and is effected by expansion/pressurised, it will just crack apart because the layer "melted" by the solvent is very thin.
This is proven by these things always failing at the seam. :)
x 5672
Shame. The pipes I have welded with it were not subject to heat or pressure - not much anyway.
I have some here that my son is hoping will repair his fairing from when he dropped his motorbike.
