Can anyone confirm they have successfully installed map update 21.0.0-r0
PSA NAC RCC Updates
gcdec
Re: PSA NAC RCC Updates - Map version 21.0.0-r0 failed to install
Hello, I had no problem a few months ago updating my maps to 20.0.0-r0. My car is wave 4, and has the most up to date firmware installed 44-07-33-32_NAC-r0. I saw there was a new map update 21.0.0-r0. I downloaded it. I formatted my 32gb sandisk usb stick to Fat32, and using 7zip sent files straight to usb stick. I am using windows 11. Went in my car and started it and turned off start stop, engine running, but every time I insert usb stick in car and press install on the screen a message comes up straight away saying map eur failed. Cant understand why as I have done exactly the same as I did with the map update 20.0.0-r0. If someone could help me get this problem sorted I would be so so grateful. @rui_saraiva
kazulbek_87
kazulbek_87 wrote: 15 Oct 2026, 11:52Thank you for the answer and the license.rui_saraiva wrote: 15 Oct 2026, 11:18 @kazulbek_87:
The 44.06.44.22_NAC-r1 firmware version is exactly the same code as the 44.06.44.22_NAC-r0 version, but with a certificate valid until November 18, 2028 (just like the 44.07.33.32_NAC-r0). If you already have a 44.07.05.22_NAC-r0 or 44.07.33.32_NAC-r0 version, you can't install this "new" 44.06.44.22_NAC-r1.
License for the 44.07.33.32_NAC-r0 and your car:
https://majestic-web.mpsa.com/mjf00-web ... D4D964224A
Currently, I have version 43.04.26.52 installed.
Today I will try to install version 44.07.33.32
I downloaded 44.07.33.32_NAC-r0 from the website, but the file size doesn't match.
The file I downloaded is 6 164 270 KB and 6 164 268 KB!!!
rui_saraiva
- x 63
Code: Select all
> curl --head https://majestic-web.mpsa.com/nas/eu/mjb00/PSA/mjbsu/PSA_ovip-int-firmware-version_44-07-33-32_NAC-r0_NAC_EUR_WAVE4.tar
HTTP/1.1 200
Accept-Ranges: bytes
ETag: W/"6312212480-1768999041000"
Last-Modified: Wed, 21 Jan 2026 12:37:21 GMT
Content-Type: application/x-tar
Content-Length: 6312212480
Date: Thu, 15 Oct 2026 19:09:04 GMT
X-PSARP: pywb5c1
Set-Cookie: PSACountry=PT; Domain=.mpsa.com; Secure; Path=/The "Size" in my table is still correct.
kazulbek_87
I can see that everything is correct in the table, but when I download it, the file is incomplete. I can't figure out whyrui_saraiva wrote: 15 Oct 2026, 20:12Content-Length: 6312212480Code: Select all
> curl --head https://majestic-web.mpsa.com/nas/eu/mjb00/PSA/mjbsu/PSA_ovip-int-firmware-version_44-07-33-32_NAC-r0_NAC_EUR_WAVE4.tar HTTP/1.1 200 Accept-Ranges: bytes ETag: W/"6312212480-1768999041000" Last-Modified: Wed, 21 Jan 2026 12:37:21 GMT Content-Type: application/x-tar Content-Length: 6312212480 Date: Thu, 15 Oct 2026 19:09:04 GMT X-PSARP: pywb5c1 Set-Cookie: PSACountry=PT; Domain=.mpsa.com; Secure; Path=/
rui_saraiva
- x 63
The Citroën/DS/Opel/Peugeot/Vauxhall Update is offering again the 44.07.33.32_NAC-r0 firmware version for all the NAC_EUR_WAVE4 infotainment systems.
Unfortunately, that particular file - https://ds4emloty3shq.cloudfront.net/CO ... _WAVE4.tar - still has invalid signing certificates and is impossible to install (you'll see the generic "Version not compatible with hardware" error).
An older file, still hosted in the PSA server and linked from my page - https://majestic-web.mpsa.com/nas/eu/mj ... _WAVE4.tar - has valid signing certificates until 18 November 2026. Both files have 6 312 212 480 bytes, but only the latter is still possible to install.
At least, and until that 18 November 2026, if you want to install the latest firmware, you can use the official software to correctly prepare the USB flash drive (with a valid license for your car and for that firmware version), delete the "SWL" folder (keeping the "license" folder with the valid license), and extract the .tar file (*) linked from my age.
(*) Avoid WinZip (or disable the default "smart CR/LF conversion" setting) and just use a recent version of 7-Zip, that also supports PAX Headers, which is used in these files.
gcdec
Is there anyone on here that can help me - the Sandisk 32gb usb stick was brand new and only used once to install map update version 20. But no matter what I do I cant get map update 21 installed.gcdec wrote: 15 Oct 2026, 15:49 Hello, I had no problem a few months ago updating my maps to 20.0.0-r0. My car is wave 4, and has the most up to date firmware installed 44-07-33-32_NAC-r0. I saw there was a new map update 21.0.0-r0. I downloaded it. I formatted my 32gb sandisk usb stick to Fat32, and using 7zip sent files straight to usb stick. I am using windows 11. Went in my car and started it and turned off start stop, engine running, but every time I insert usb stick in car and press install on the screen a message comes up straight away saying map eur failed. Cant understand why as I have done exactly the same as I did with the map update 20.0.0-r0. If someone could help me get this problem sorted I would be so so grateful. @rui_saraiva
Can anyone confirm they have successfully installed map update 21.0.0-r0![]()
