PSA NAC RCC Updates
gcdec
Re: PSA NAC RCC Updates - Map version 21.0.0 failed to install
Onlinekazulbek_87
kazulbek_87 wrote: Yesterday, 11:52Thank you for the answer and the license.rui_saraiva wrote: Yesterday, 11:18 @kazulbek_87:
The 44.06.44.22_NAC-r1 firmware version is exactly the same code as the 44.06.44.22_NAC-r0 version, but with a certificate valid until November 18, 2028 (just like the 44.07.33.32_NAC-r0). If you already have a 44.07.05.22_NAC-r0 or 44.07.33.32_NAC-r0 version, you can't install this "new" 44.06.44.22_NAC-r1.
License for the 44.07.33.32_NAC-r0 and your car:
https://majestic-web.mpsa.com/mjf00-web ... D4D964224A
Currently, I have version 43.04.26.52 installed.
Today I will try to install version 44.07.33.32
I downloaded 44.07.33.32_NAC-r0 from the website, but the file size doesn't match.
The file I downloaded is 6 164 270 KB and 6 164 268 KB!!!
rui_saraiva
- x 63
Code: Select all
> curl --head https://majestic-web.mpsa.com/nas/eu/mjb00/PSA/mjbsu/PSA_ovip-int-firmware-version_44-07-33-32_NAC-r0_NAC_EUR_WAVE4.tar
HTTP/1.1 200
Accept-Ranges: bytes
ETag: W/"6312212480-1768999041000"
Last-Modified: Wed, 21 Jan 2026 12:37:21 GMT
Content-Type: application/x-tar
Content-Length: 6312212480
Date: Thu, 15 Oct 2026 19:09:04 GMT
X-PSARP: pywb5c1
Set-Cookie: PSACountry=PT; Domain=.mpsa.com; Secure; Path=/The "Size" in my table is still correct.
Onlinekazulbek_87
I can see that everything is correct in the table, but when I download it, the file is incomplete. I can't figure out whyrui_saraiva wrote: Yesterday, 20:12Content-Length: 6312212480Code: Select all
> curl --head https://majestic-web.mpsa.com/nas/eu/mjb00/PSA/mjbsu/PSA_ovip-int-firmware-version_44-07-33-32_NAC-r0_NAC_EUR_WAVE4.tar HTTP/1.1 200 Accept-Ranges: bytes ETag: W/"6312212480-1768999041000" Last-Modified: Wed, 21 Jan 2026 12:37:21 GMT Content-Type: application/x-tar Content-Length: 6312212480 Date: Thu, 15 Oct 2026 19:09:04 GMT X-PSARP: pywb5c1 Set-Cookie: PSACountry=PT; Domain=.mpsa.com; Secure; Path=/
