Changed security settings for this site
Forum News, Announcements and any issues you're having with the forum
x 1953
Re: Changed security settings for this site
Unread post by Paul-R »
I got the Error 1015 as well. I reckon it's because whenever I refresh the Active Topics page I keep open I open tabs up of all the new posts. I can easily have 10, 15 or more open depending on how long it's been since I last refreshed the screen. I could go to the first 4 or 5 without a problem but after that the tab had the message. A simple F5 refresh gets the page I want.
So I'm obviously demanding more resources than the system thinks I should have. No need to log out and back in at all.
x 1481
Unread post by xantia_v6 »
I just enabled the rate limits today, I will adjust the threshold.
x 1481
I have reconfigured the blocking rules which should now be less likely to catch legitimate users.
The lockout period should only be 10 seconds.
x 2007
Unread post by Stickyfinger »
myglaren wrote: 17 Sep 2026, 20:24
Yep....I have been getting that as well...and every time I visit the site I get the human check
x 1481
Stickyfinger wrote: 18 Sep 2026, 05:26
Did you get the error 1015 after 3:11 am?
When you get the human check, were you previously logged out of the forum?
x 3298
I normally have several tabs open in 'Edge', with this Forum being the first one. I will browse through these tabs, and if I am 'away' from the Forum tab for more than around 15 minutes, I get the 'Human' check when I refresh the 'Forum' tab.
Huskyxantia
x 928
Unread post by Huskyxantia »
Bot check human verification tick box , tick , im in ok did notice it was crashing several days ago all seems normal now
:-D
x 1481
If you are reporting issues in this topic, please give the time and date of when the symptoms were last observed.
Although I may just have worked out why people are unexpectedly getting the human test.
x 1481
As of now, I have reconfigured again, which should eliminate the false positives.
Couldn't get in late last night and got the "you have been temporarily banned message". I do log in several times a day so maybe I exceeded the previous limit.
Got in this morning to back to normalish..although still got the no graphics initial screen which I needed to refresh.
Thanks Mike for your expertise in sorting these things out and keeping the forum flowing when these problems crop up.
Kind regards
x 8165
First issue I have had, at viewtopic.php?p=876145#p876145
2 mins ago I entered that post, clicked 'Submit' and got:
Error screen
Error screen
I waited 20 secs or so and clicked the recycle/refresh icon and it went through as normal. :)
x 2007
xantia_v6 wrote: 18 Sep 2026, 06:58
1015 = went to bed about 24oo
Yes, was logged out
lawns
x 3
Unread post by lawns »
Hi just to report that since change to security setting, when I make a search engine selection for FCF I get the following image at 20.14 18/09/2026.
[attachment=0]test2.jpg[/attachment]
Is this correct as can select board index and pass human check to view board as normall.
x 1481
I have admitted defeat for now, and put the Cloudflare settings back to what they have been for the past year or so. I have learned a bit along the way, and it is very difficult to distinguish a bot without an account from a legitimate user who has not logged-in yet.
The good news is that the bot attack seems to have subsided now, the number of "guest" users has reduced from around 9000 to about 700 and has been stable there for a few hours.
x 5679
I was a bit surprised to log straight in without any impedance whatsoever.
"In total there are 639 users online :: 22 registered, 2 hidden and 615 guests (based on users active over the past 10 minutes)"
