Changed security settings for this site
Forum News, Announcements and any issues you're having with the forum
x 1938
Re: Changed security settings for this site
I got the Error 1015 as well. I reckon it's because whenever I refresh the Active Topics page I keep open I open tabs up of all the new posts. I can easily have 10, 15 or more open depending on how long it's been since I last refreshed the screen. I could go to the first 4 or 5 without a problem but after that the tab had the message. A simple F5 refresh gets the page I want.
So I'm obviously demanding more resources than the system thinks I should have. No need to log out and back in at all.
x 1445
Unread post by xantia_v6 »
I just enabled the rate limits today, I will adjust the threshold.
x 1445
I have reconfigured the blocking rules which should now be less likely to catch legitimate users.
The lockout period should only be 10 seconds.
x 1997
Unread post by Stickyfinger »
myglaren wrote: 17 Sep 2026, 20:24
Yep....I have been getting that as well...and every time I visit the site I get the human check
x 1445
Stickyfinger wrote: Yesterday, 05:26
Did you get the error 1015 after 3:11 am?
When you get the human check, were you previously logged out of the forum?
x 3302
I normally have several tabs open in 'Edge', with this Forum being the first one. I will browse through these tabs, and if I am 'away' from the Forum tab for more than around 15 minutes, I get the 'Human' check when I refresh the 'Forum' tab.
Huskyxantia
x 898
Unread post by Huskyxantia »
Bot check human verification tick box , tick , im in ok did notice it was crashing several days ago all seems normal now
:-D
x 1445
If you are reporting issues in this topic, please give the time and date of when the symptoms were last observed.
Although I may just have worked out why people are unexpectedly getting the human test.
x 1445
As of now, I have reconfigured again, which should eliminate the false positives.
x 7164
Couldn't get in late last night and got the "you have been temporarily banned message". I do log in several times a day so maybe I exceeded the previous limit.
Got in this morning to back to normalish..although still got the no graphics initial screen which I needed to refresh.
Thanks Mike for your expertise in sorting these things out and keeping the forum flowing when these problems crop up.
Kind regards
x 8083
First issue I have had, at viewtopic.php?p=876145#p876145
2 mins ago I entered that post, clicked 'Submit' and got:
Error screen
Error screen
I waited 20 secs or so and clicked the recycle/refresh icon and it went through as normal. :)
x 1997
xantia_v6 wrote: Yesterday, 06:58
1015 = went to bed about 24oo
Yes, was logged out
lawns
x 3
Unread post by lawns »
Hi just to report that since change to security setting, when I make a search engine selection for FCF I get the following image at 20.14 18/09/2026.
[attachment=0]test2.jpg[/attachment]
Is this correct as can select board index and pass human check to view board as normall.
