Changed security settings for this site
Forum News, Announcements and any issues you're having with the forum
x 1481
Unread post by xantia_v6 »
Due to an uptick of unwanted "guest" traffic (over 5000 users in 5 minutes), I have adjusted our Cloudflare configuration to reduce the server load.
I think that this should be transparent to our legitimate users, but let me know if your use of the forum is being impacted.
Ignore anything is the half hour before this post, as I was trying different settings, some of which were a bit draconian.
x 8165
Re: Changed security settings for this site
I've been on the forum since 8am and not noticed anything untoward at all! :)
x 5679
All OK up to now.
Having problems with a US forum. Almost impossible to even log in, never mind read anything. Same reason, lots of bots. The owners rarely surface these days though.
Just get these responses:-
Resource Limit Is Reached
The website is temporarily unable to service your request as it exceeded resource limit. Please try again later.
Currently Active Users: 9872 (1 members and 9871 guests)
x 1481
This forum was nowhere near crashing, but it was running at significantly elevated CPU loading. Adjusting the Cloudflare configuration seems to have dropped the CPU load by about 70%
x 3298
I had (for a few moments) a 'bot check' type of screen when I did a refresh, and then the forum went back to normal.
Sloppysod
x 406
Unread post by Sloppysod »
Apart from cloud fire security page, that lasted 1 or 2 seconds, everything is fine on Waterfox mobile.
Stu 🏴󠁧󠁢󠁷󠁬󠁳󠁿
x 3298
This time I had the 'bot check' followed by the tick box screen.
x 1952
Unread post by Paul-R »
Sloppysod wrote: 16 Sep 2026, 11:04Apart from cloud fire security page, that lasted 1 or 2 seconds...
Same for me a couple of hours ago.
Stonehopper
x 120
Unread post by Stonehopper »
Bot check to ask if I was human - passed. (Must be something wrong!).
Derek
x 5679
Had this yesterday and again this morning.
Followed by the botcheck.
x 1481
myglaren wrote: 17 Sep 2026, 09:44 Had this yesterday and again this morning.
Was that on your first visit to the forum after a few hours inactivity?
Did you access the forum by clicking a link on a forum page, or a bookmark or something else?
x 5679
First time yesterday was after a reboot. The one this morning was after being shut down overnight.
I always run the browser cleaners as I shut them down, then run BleachBit before turning off so there are no cookies, site settings etc remaining.
x 1481
OK, that makes sense. If your browser doesn't have an FCF cookie, the site will initially treat you as a guest which will trigger Cloudflare to perform a challenge. I don't completely understand the page loading with no graphics (but I have also seen it here). It may be because your browser also doesn't have a Cloudflare cookie, so Cloudflare won't supply the cached images until after the challenge is completed.
x 3298
I have found that, if I don't look at pages for a while, I get the 'Human' verification screen.
x 5679
xantia_v6 wrote: 17 Sep 2026, 19:25 OK, that makes sense. If your browser doesn't have an FCF cookie, the site will initially treat you as a guest which will trigger Cloudflare to perform a challenge. I don't completely understand the page loading with no graphics (but I have also seen it here). It may be because your browser also doesn't have a Cloudflare cookie, so Cloudflare won't supply the cached images until after the challenge is completed.
Not a Problem, I can live with that if it means the bots get short shrift.
I came back to this thread to post that, and got this:-
No problem logging back in after closing that though.
