Hi Kenny, well you know how to deal with that! I followed your advice with my hydraulic motorKennyW wrote: 25 Jun 2026, 18:32
Graeme,
I'm missing all this fun with the Audi but just had to replace the starter motor, have a look at the armature in the attached photo
Kenny
New suspension spheres!
aerodynamica
- x 216
Re: New suspension spheres!
Graeme M
KennyW
- x 165
Thanks Graeme,
I've still not resolved my starting problem, it looks electrical as both battery and starter motor are new and ran fine for 5 days then it refused to start no warning.
I hope your problem is resolved soon can'thelp but will offer moral support.
Kenny
Kenny
C3 1.4 petrol (SWMBO)
michok2
have you removed steal lines before "hammer time"?aerodynamica wrote: 25 Jun 2026, 08:41 Hi it took a lot of attempts before the mounting broke. The sphere was immensely tight. Possibly corrosion. All 7 spheres on my C5 were as tight as this. I was Possibly unlucky.
This time how did you remove it?aerodynamica wrote: 25 Jun 2026, 08:41 I fitted the sphere 3 years ago with a film of grease at the mating faces and also tightened it to hand tightness. Despite these precautions I found that it was again very stuck. So I don't really understand why.
aerodynamica
- x 216
this time I didn't remove it. It feels very soft at the front and I believe the centre sphere is still good after 3 years. I was simply curious to remove it because I had the subframe off.michok2 wrote: 13 Jul 2026, 06:46have you removed steal lines before "hammer time"?aerodynamica wrote: 25 Jun 2026, 08:41 Hi it took a lot of attempts before the mounting broke. The sphere was immensely tight. Possibly corrosion. All 7 spheres on my C5 were as tight as this. I was Possibly unlucky.
As for your first question: I would remove the steel pipes for the front hydractive block. You have to remove all pipes, electrical plug and 3x mounting screws to remove the whole thing out the corner behind the engine. Then remove the sphere when you clamp the hydractive block with a bench vise.
Only if you are lucky will you fibs the sphere comes off alone. I was not so lucky.
Graeme M
michok2
why? easy to brake those?aerodynamica wrote: 13 Jul 2026, 09:10 I would remove the steel pipes for the front hydractive block.
