Xantia Central Locking
Huskyxantia
x 924
Re: Xantia Central Locking
Unread post by Huskyxantia »
xf1ref wrote: 14 Aug 2018, 18:49 Hi,
This is valid for Xantia Phase 2 - inside the front doors lock mechanism are two micro switches. One micro switch is for courtesy light and the other one is for detecting if the door is closed or open. If this micro switch it's broken the central locking will detect that the door is open and will not lock the car.
The rear doors mechanism contains only the micro switch for courtesy light and you can lock the car even if one rear door is open.
Maybe for Phase 1 only the driver door has the functionality to detect if the door is open and to send the signal to lock/unlock all the doors.
Sorry this has lost me, where would i wire the after market kit to then ?
My car locks and unlocks on key but im wanting remote central locking ... Lazy and getting old !!
:-D
x 1471
Unread post by xantia_v6 »
Huskyxantia
x 924
xantia_v6 wrote: 14 Aug 2018, 20:05 See: viewtopic.php?t=45854#p383762
Top man thank you so much.
:-D
introfusion123
Unread post by introfusion123 »
Do You Have a schematic of central lock ? I want to install a aftermarket distante lock-unlock remote
https://altex.ro/kit-inchidere-centrali ... 2IEALw_wcB
Huskyxantia
x 924
introfusion123 wrote: 04 May 2021, 08:11 Do You Have a schematic of central lock ? I want to install a aftermarket distante lock-unlock remote
If you already have central locking fitted what I'd do is find out the earths on the after market kit and earth them there be more than one, Locate the live that works the door locks and splice into that with the live on the kit,
Option 2 .
If its a full kit with the pump lock parts someone on here will give the correct name I can't spell that good, position these so they can push the locking bars up and down , your have to self tap them to small pilot holes.
Tap into a permanent live cigar lighter is OK, as long as you have a fuse on the line your be fine and earth it too.
:-D
Huskyxantia
x 924
Different car but may shed some light on how to do,
I did mine over 6 years ago so memory's a bit faded hope you get it sorted.
:-D
introfusion123
My issue was , when i connected on Door , its locks and automaticaly unlocks , what shoud i do?
x 3296
That suggests that either a lock switch or the wiring for the switch has failed. When you lock the car the locking system takes a look at the various switches (to see that all of the doors are closed and locked). If it does not see the right outcome it then unlocks the car again. Try looking at the wiring in the concertina grommets to the rear doors first, as this is a known area for wiring to fail.
Huskyxantia
x 924
Sounds like one of the door lock motors has died, I'd also check the door wire looms from door pillar to door the wires can brake and cause an earth problem.
If you can and it is fiddly unplug each lock and see if the problem stops do this one at a time this should find the dead lock motor, the motors are not to expensive look on eBay.
:-D
Huskyxantia
x 924
If your thinking of an after market kit you still need to find the dead lock motor and replace it so the after market kit will work, I'm soon going to fit a remote locking kit to a 206cc I've got to find my live that locks and unlocks the doors that's if the bsi will let me, I then connect the kits live to that wire and the rest as like before are earths, Good luck with your locking issue .
:-D
