Colin
Xantia 2.0i 16v VSX ignition problem R reg
admiral51
- (Donor 2026)
- x 391
- x 8309
admiral51
- (Donor 2026)
- x 391
- x 8309
admiral51
- (Donor 2026)
- x 391
Found my way to Maplins- so much for an electrician mate- havent spoken to him for 2 years turns out he now drives buses for a living
Got myself a new crimp tool (£24 you were not joking were you Jim
) and the crimps all set to do the job but no 50 amp wire available
Will have to postpone till later in the week
Colin
Colin
- x 5654
red_dwarfers
- x 58
- x 5654
Or Richer Sounds may have some at a reasonable price - I bought my 30A speaker wire there and it wasn't too bad - about £5 a metre for bi-wire (no, not that sort of bi ) you only need a single so should be about ¼ of that price.red_dwarfers wrote:I picked up some high ampage wire in the audio section of Halfrauds
- x 8309
admiral51
- (Donor 2026)
- x 391
Right still no luck in finding the right wire
I have been told i can get some 50 amp wire but i could do with some guidance cos im a little confused
Does the thickness of the wire make any difference or providing it is rated correctly will any size do
Have tried 2 local motor factors and CEF and still no joy-just thought it would be a simple job and yet im struggling to get the wire
I have had a look here in particular Ref 97 and Ref 120 .Is it possible that this is the correct wire
Colin
Colin
- x 8309
- x 8309
In the website you mentioned Colin, Ref 33 in the thinwall section will be just the job I reckon.
It's 33 amp stuff but given the blower/HRW is on a different feed, this should be adequate.
I was being a bit too on the conservative side with a 50 amp rating, completely forgetting it does not carry the hugely high current taken by the blower and HRW
Give the factors another try for that stuff...
admiral51
- (Donor 2026)
- x 391
Thanks JimCitroJim wrote:
I was being a bit too on the conservative side with a 50 amp rating, completely forgetting it does not carry the hugely high current taken by the blower and HRW![]()
Not sure if im going to need to rewire the Blower/HRW feed as well yet and that is a 60 amp fuse...may try that web site and order a selection from thinwall Refs 33/39/50 just so i have some in stock
Will report back on thursday away again tomorrow night
Colin
Clogzz
- x 40
admiral51
- (Donor 2026)
- x 391
Hi Clogzz as im not too clever with electrics am i correct in assuming that if i run two 25A wires into each crimp and crimp that to the single original wire all should be okClogzz wrote:In electronics, we find parallel wiring in high current circuits.
Two 25A wires will carry a bit more than 50A.
Colin
