Xantia 2.0i 16v VSX ignition problem R reg
admiral51
(Donor 2026)
x 391
Unread post by admiral51 »
Just to clarify things Jim when you say butt crimps do you mean the bullet type or the blade type similar to those used on the relays :? :?
Colin
x 8336
The in-line crimp joints Colin. they look like bullet connectors but they take two bare ends of wires in each end.
If you can wait five minutes, I'll go and post a picture of one up on here...
admiral51
(Donor 2026)
x 391
Thanks Jim i know the ones may just be able to aquire a prpoer tool from an electrician mate heres hoping :D
Colin
x 8336
These are Butts Colin..
And this is an example of a fairly good quality crimp tool...
admiral51
(Donor 2026)
x 391
Found my way to Maplins- so much for an electrician mate- havent spoken to him for 2 years turns out he now drives buses for a living :lol: :lol:
Got myself a new crimp tool (£24 you were not joking were you Jim :wink: ) and the crimps all set to do the job but no 50 amp wire available :cry: :cry:
Will have to postpone till later in the week
Colin
x 5669
Try an electrical factor for 50A cable. City Electrical Factors if you can't find any other.
red_dwarfers
x 58
Unread post by red_dwarfers »
I picked up some high ampage wire in the audio section of Halfrauds :wink:
Kev
'19 C4 Cactus 130 Flair
x 5669
red_dwarfers wrote:I picked up some high ampage wire in the audio section of Halfrauds :wink:
Or Richer Sounds may have some at a reasonable price - I bought my 30A speaker wire there and it wasn't too bad - about £5 a metre for bi-wire (no, not that sort of bi ) you only need a single so should be about ¼ of that price.
x 8336
Or any good motor factors wil have the right stuff.
admiral51
(Donor 2026)
x 391
Right still no luck in finding the right wire :evil: :evil:
I have been told i can get some 50 amp wire but i could do with some guidance cos im a little confused :oops: :oops:
Does the thickness of the wire make any difference or providing it is rated correctly will any size do :? :?
Have tried 2 local motor factors and CEF and still no joy-just thought it would be a simple job and yet im struggling to get the wire :roll:
I have had a look here in particular Ref 97 and Ref 120 .Is it possible that this is the correct wire :) :)
Colin
x 8336
Colin,
I'm sure I have something suitable here. It's buried deeply in my stash though so it'll involve ladders and fighting off attic-mosters. I'll go and have a look in a bit..
If I have, you're welcome to however much you need.
I'll report back in a bit...
x 8336
:evil: Just had a look and what I thought would be OK turned out to me mains cable for conduit wiring. It's not suitable; too stiff.
In the website you mentioned Colin, Ref 33 in the thinwall section will be just the job I reckon.
It's 33 amp stuff but given the blower/HRW is on a different feed, this should be adequate.
I was being a bit too on the conservative side with a 50 amp rating, completely forgetting it does not carry the hugely high current taken by the blower and HRW :oops:
Give the factors another try for that stuff...
admiral51
(Donor 2026)
x 391
Thanks Jim :) :)
Not sure if im going to need to rewire the Blower/HRW feed as well yet and that is a 60 amp fuse...may try that web site and order a selection from thinwall Refs 33/39/50 just so i have some in stock :lol: :lol:
Will report back on thursday away again tomorrow night :( :(
Colin
Clogzz
x 40
Unread post by Clogzz »
In electronics, we find parallel wiring in high current circuits.
Two 25A wires will carry a bit more than 50A.
admiral51
(Donor 2026)
x 391
Clogzz wrote:In electronics, we find parallel wiring in high current circuits.
Hi Clogzz as im not too clever with electrics am i correct in assuming that if i run two 25A wires into each crimp and crimp that to the single original wire all should be ok [-o<
Colin
