PSA NAC RCC Updates
tunahan12
Re: PSA NAC RCC Updates
Hello, i've read my UIN with Arduino. But when i'm trying to download a license, i'm facing this error:
UIN: 3244303735303339303032383530363433363735
rui_saraiva
- x 65
You have to convert that to hexadecimal, your UIN is 2D075039002850643675:
https://majestic-web.mpsa.com/mjf00-web ... 2850643675
tunahan12
I don't know what to say.. Thank you so much, really! You made my day!! Although i can't still use Android Auto with my phone, this is really relieved me.rui_saraiva wrote: 22 Jul 2026, 18:51 You have to convert that to hexadecimal, your UIN is 2D075039002850643675:
Martin03
Hi Rui,
I have some good news.
I prepared a new USB flash drive using Peugeot Update on a Windows PC instead of macOS, and the map update completed successfully. Everything is now working perfectly.
So the issue was indeed related to preparing the USB on macOS, even though I had already removed the hidden files and verified that there were no extra files in the MAP folder.
Thank you very much for your help and for pointing me in the right direction. I really appreciate the time you took to help me solve this problem.
Thanks again for everything you do for the PSA/Stellantis community!
Pete-69
New member says hi!
I have a DS7 Crossback E-tense 2019. A few days ago MyDS app told me there is a new software available to my car, version: 42.03.33.42_NAC-r0.
Current version in my car is: 44.07.33.32_NAC-r0 (from 2023-08-21). I thought WTF...
Well, I did download the version MyDS announced to the USB stick, but it didn't even recognized in the car.
I read this topic and special thanks to Rui Saraiva, here is a lot of information.
My car´s VIN-code tells: From factory, my car had a NAC_EUR_WAVE3 infotainment system.
But in reality my car currently has a NAC_EUR_WAVE4 system. So, the information stored in the Stellantis servers was not updated.
For some reason today MyDS had updated itself, and did not notify of new updates, and the version reported by the app had updated to the version what is in the car. Maybe it was updated yesterday via Google Android Auto, I don't know.
So something has been done on the Stellantis servers...
Boothy91
Just updated wave 2 to 31, don't know what's changed but it's available now.
Tiago2196
So I just bought a C4 cactus that had a older update. I installed my Citroen and downloaded and prepared the USB drive like they said. The update installed successfully but it seem to have broken the navigation system because I can no longer use him. It gives me a weird error to reboot the system and download the map update again, but I only downloaded the touchscreen update that was available. And after that mycitroen still shows me to update to (42.03.33.42_NAC-r0) but this is the version that I installed...
I've tried everything, do I need to install the Maps manually? And I know there is a more updated version of the system, do I need to update to a newer version manually too?
Vin : VF7**************[VIN obfuscated, can be read by forum staff]
rui_saraiva
- x 65
@Tiago2196: You've just converted your NAC_EUR_WAVE3 (3x.0x.xx.xx) to a NAC_EUR_WAVE4 (4x.0x.xx.xx) system and in the process the installed map was deleted (maps for a specific Wave level are only compatible with systems of that Wave level). Because that conversion was not reported back to the Stellantis servers, they still think you have a NAC_EUR_WAVE3 system and the Citroën Update/MyCitroën will only offer you updates for that Wave 3.
Until Stellantis identifies your system as a NAC_EUR_WAVE4:
* You need to manually prepare the USB flash drive with the NAC_EUR_WAVE4 map (latest European version is 20.0.0-r0);
* You can't update the system/firmware.
Tiago2196
Thank you very much, I will wait for the system update then.rui_saraiva wrote: 26 Jul 2026, 02:29 @Tiago2196: You've just converted your NAC_EUR_WAVE3 (3x.0x.xx.xx) to a NAC_EUR_WAVE4 (4x.0x.xx.xx) system and in the process the installed map was deleted (maps for a specific Wave level are only compatible with systems of that Wave level). Because that conversion was not reported back to the Stellantis servers, they still think you have a NAC_EUR_WAVE3 system and the Citroën Update/MyCitroën will only offer you updates for that Wave 3.
To update maps do I need the license file?
rui_saraiva
- x 65
@Tiago2196: No, there are no license for map updates.
Robert_669830
There is also an update for WAVE1 with number 29. The files inside are dated November 10, 2025.
rui_saraiva
- x 65
@Robert_669830: No, that's an old version. It has an UpdateID of 002315011730118916
The next European map version for the NAC_EUR_WAVE1 will be 32.0.0:
Code: Select all
> date -d @1730118916
Mon Oct 28 12:35:16 PM GMT 2024Code: Select all
"updateType": "map-eur",
"updateVersion": "32.0.0",
"updateProvider": "TOMTOM",
"updateId": "002315011776062834",
"updateDate": "2026/05/29 11:16:50",
"updateStatus": {
"code": "AVC",
"label": "En attente de validation fournisseur"
}Code: Select all
> curl --head https://majestic-web.mpsa.com/. . . .tar
HTTP/1.1 200
Accept-Ranges: bytes
ETag: W/"10972006400-1780046106000"
Last-Modified: Fri, 29 May 2026 09:15:06 GMT
Content-Type: application/x-tar
Content-Length: 10972006400
Date: Sun, 26 Jul 2026 20:55:44 GMT
X-PSARP: bewb5c1
Set-Cookie: PSACountry=PT; Domain=.mpsa.com; Secure; Path=/-
MDRAGOGIAS
Το ξερω οτι εχεις κουραστει να σε ρωτανε αλλα εχω ενα citroen c5 aircross hybrid 1600 225 hp 2021 δεν μπορω να κανω update εχω την πρωτη εκδοση λογισμικου. τι κανω μετα
- x 5679
Please post in English only. Use i.e Google Translate or DeepL.
MDRAGOGIAS
I know you're tired of being asked but I have a citroen c5 aircross hybrid 1600 225 hp 2021 I can't update I have the first software version. what do I do next vin VR7**************[VIN obfuscated, can be read by forum staff]
