PSA NAC RCC Updates
- x 5674
Re: PSA NAC RCC Updates
What are we supposed to do with this? As it is a Toyota we are unlikely to be able to provide any useful advice, but need to know what you want to know.
rui_saraiva
- x 65
You have an RCC_EU_W3_ECO infotainment system with the firmware version 5_093_20.0H022.3 installed (you can see the system version 093x in the previous screen of those HMI/iMX/V850 versions). You can upgrade the firmware (latest is 6_0432_23.2I44.1), but you won't see anything new.
rui_saraiva
- x 65
Some Toyota also have these NAC and RCC systems. There isn't an official "Toyota Update" software just like the "Citroën/DS/Opel/Peugeot/Vauxhall Update", but the official https://www.toyota-tech.eu/ site usually has some support for those systems. And the manual method of extracting the .tar update to a FAT32-formatted USB flash drive works fine.myglaren wrote: 02 Apr 2026, 09:46 What are we supposed to do with this? As it is a Toyota we are unlikely to be able to provide any useful advice, but need to know what you want to know.
The update files are exactly the same (for the same hardware and Wave level).
Code: Select all
[rmps@XPS7590] ~/psa 0> psa-ecutype.sh YARERHNS3GJ002779
Verifying Toyota (Belgium) [2016] VIN YARERHNS3GJ002779...
* YARERHNS3GJ002779: RCC_EU_W3_ECO
[rmps@XPS7590] ~/psa 0> psa-update.sh --debug=trace YARERHNS3GJ002779
Checking updates for VIN YARERHNS3GJ002779 (Toyota (Belgium) [2016])...
"requestResult": "OK",
"installerURL": "https://majestic.mpsa.com/mjf00-web/rest/UpdateDownload?updateId=000000001570806588&uin=00000000000000000000&type=fw",
"vin": "YARERHNS3GJ002779",
"software": [
"softwareType": "rcc-firmware",
"updateRequestResult": "OK",
"currentSoftwareVersion": "5_0931_20.0H023",
"update": [
"updateId": "005315191766140259",
"updateSize": "8391587840",
"updateVersion": "6_0432_23.2I44.1",
"updateDate": "2025-01-27 04:34:43.0",
"updateURL": "https://majestic-web.mpsa.com/mjf00-web/rest/UpdateDownload?updateId=005315191766140259&uin=2D075039002971977050&type=fw",
"licenseURL": "https://majestic-web.mpsa.com/mjf00-web/rest/LicenseDownload?mediaVersion=005315191766140259&uin=2D075039002971977050"
RCC Firmware rcc-firmware update available for current version 5_0931_20.0H023: 6_0432_23.2I44.1
Papfik
It's the same as a Citroen Berlingo but Toyota brandedmyglaren wrote: 02 Apr 2026, 09:46 What are we supposed to do with this? As it is a Toyota we are unlikely to be able to provide any useful advice, but need to know what you want to know.
How to update? Both CarPlay and Android Auto are not working sadlyrui_saraiva wrote: 02 Apr 2026, 15:15You have an RCC_EU_W3_ECO infotainment system with the firmware version 5_093_20.0H022.3 installed (you can see the system version 093x in the previous screen of those HMI/iMX/V850 versions). You can upgrade the firmware (latest is 6_0432_23.2I44.1), but you won't see anything new.
rui_saraiva
- x 65
In that previous screen, where you see the "System version: 0931x", that "x" should be a letter "A" to "D". If your hardware variant is "A" or "B", unfortunately there is nothing you can do - it lacks the hardware to support CarPlay and/or Android Auto. If it is the "C" or "D" variants, it should work fine with a good USB data cable. Some Toyota have the Android Auto disabled from factory, but could be enabled through the OBD port.Papfik wrote: 02 Apr 2026, 16:28It's the same as a Citroen Berlingo but Toyota brandedmyglaren wrote: 02 Apr 2026, 09:46 What are we supposed to do with this? As it is a Toyota we are unlikely to be able to provide any useful advice, but need to know what you want to know.![]()
How to update? Both CarPlay and Android Auto are not working sadlyrui_saraiva wrote: 02 Apr 2026, 15:15You have an RCC_EU_W3_ECO infotainment system with the firmware version 5_093_20.0H022.3 installed (you can see the system version 093x in the previous screen of those HMI/iMX/V850 versions). You can upgrade the firmware (latest is 6_0432_23.2I44.1), but you won't see anything new.![]()
KJSlayer
@rui_saraiva , do you have any advice what would be a best course of action? Should I put the update file from your site without a licensce on the USB stick? Or should I combine this update with the license from Peugeot App, or maybe do I need to generate a license file on my own and put it on USB stick along with the update?KJSlayer wrote: 28 Mar 2026, 16:14 Hi,
I have a Peugeot 508 II 2021, I wanted to update the firmware of i-Cockpit, now I have 42.03.31.32_NAC-r0 and Peugeot Update App gives me an option to update to 44.07.33.32_NAC-r0. I was able to update the maps to 17.0.0-r0 but when I try to update the firmware I get "Version not compatible with hardware". I have tried downloading the 44.07.33.32_NAC-r0 manually from a site from a previous comment and activating the WiFi before putting the USB stick in the car but this didn't resolve the issue. Could this be an issue with the license, how do I generate it on my own? Because I don't know how to generate it for my car/update version. My chassis number is VR3**************[VIN obfuscated, can be read by forum staff]**************[VIN obfuscated, can be read by forum staff]**************[VIN obfuscated, can be read by forum staff]. Thanks in advance for any advice
rui_saraiva
- x 65
@KJSlayer: After creating the installation USB drive with the Peugeot Update (that also includes the license file), extract the .tar file from my site (don't use WinZip) to overwrite the files on the USB flash drive.
KJSlayer
That has finally worked, thanks a lot for the help!rui_saraiva wrote: 02 Apr 2026, 18:38 @KJSlayer: After creating the installation USB drive with the Peugeot Update (that also includes the license file), extract the .tar file from my site (don't use WinZip) to overwrite the files on the USB flash drive.
Solarriors
- x 7
Is there anything that was locked behind a subscription or telecoding ?
I saw that voice commands are subscription only and the Citroen Dealership wanted to charge me 500€ to update the maps and system !
The telemaintainance function on the MyCitroen services doesn't seem to update anything (my service is due and AdBlue is due). Are they just using it to sell data to insurance companies?
L4mbert
- New User
Hi All, Hope someone can help, tried updating my touch screen software 2021 peugwot 2008 - VIN VR3**************[VIN obfuscated, can be read by forum staff]
Peugeot update tells me update available is 44.06.44.22_NAC-r0 however there are later versions available according to this forum.
I tried this one and get message (version not compatible with hardware) called peugeot and they say because the car is over 5 years old now so they dont allow free updates. Literally a week over 5 years old.
Is anyone able to provide me with the latest update files and key file with instructions to update offline via usb?
Fingers crossed someone can help
Andrew
Andrew
mirwin
Hello everyone, I'm new here, although I've been reading your forum.
I'm having trouble updating my 2023 Peugeot 3008 II. My current firmware is: 43.04.27.52_NAC-r0. I imported the car from France and had it converted to Polish service.
I'm trying to update the firmware to the Peugeot Update version, but I always get the same error message: "Version not compatible with the hardware." What should I do? Do you have any suggestions?
Mirek
Mirek
scar1987
Boa tarde tenho um C5 AirCross de 2019, consegui atualizar atravês do aplicativo da citroen o firmware para a versão 42.03.33.42_NAC-r0 mas não estou a conseguir atualizar para a 44.07.33.32_NAC-r0 pois não aparece no aplicativo nem atualizar os mapas, consegue ajudar-me, já tentei pelos passos no terminal de mac mas não consigo fazer a licença.GiveMeABreak wrote: 01 Aug 2024, 00:31 Firmware V 21.08.87.32_NAC-r1
Instructions for Updating NAC or RCC Firmware, Maps & Licences
VIN é = VR7**************[VIN obfuscated, can be read by forum staff]
UID= 0D01251749D4F21DAFA5
- x 5674
Please post in English.
Translation:-
Translation:-
Good afternoon. I have a 2019 C5 AirCross. I managed to update the firmware to version 42.03.33.42_NAC-r0 via the Citroën app, but I can’t seem to update it to 44.07.33. 32_NAC-r0 as it doesn’t appear in the app, nor does it let me update the maps. Can you help me? I’ve already tried following the steps on the Mac terminal but I can’t get the licence to work.
VIN is = VR7**************[VIN obfuscated, can be read by forum staff]**************[VIN obfuscated, can be read by forum staff]
Translated with DeepL.com (free version)
scar1987
Good afternoon, I have a 2019 C5 AirCross. I managed to update the firmware to version 42.03.33.42_NAC-r0 through the Citroen app, but I'm unable to update to 44.07.33.32_NAC-r0 because it doesn't appear in the app, nor can I update the maps. Can you help me? I've already tried the steps in the Mac terminal, but I can't create the license.
scar1987
Good afternoon, I have a 2019 C5 AirCross. I managed to update the firmware to version 42.03.33.42_NAC-r0 through the Citroen app, but I'm unable to update to 44.07.33.32_NAC-r0 because it doesn't appear in the app, nor can I update the maps. Can you help me? I've already tried the steps in the Mac terminal, but I can't create the license.rui_saraiva wrote: 02 Apr 2026, 18:38 @KJSlayer: After creating the installation USB drive with the Peugeot Update (that also includes the license file), extract the .tar file from my site (don't use WinZip) to overwrite the files on the USB flash drive.
