PSA NAC RCC Updates
This is the Connected NAV system.
Main Features: It is a fully integrated Telematics System featuring CarPlay, Android Auto, Real Time Services, Voice Commands, High-Res Display, 3D Navigation, Bluetooth Hands Free & USB. 2 versions of the system are available NAC (Navigation Audio Connectée) and RCC (Radio Couleur Connectée) or Connected Colour Radio, which does not have the Integrated Navigation or Live Services.
Deermand
x 4
Re: PSA NAC RCC Updates
Unread post by Deermand »
Hello!
I have 508 II with NAC Wave 3, version 31.09.46.62_NAC-r0.
Could somebody help me with the licence?
VIN: VR3**************[VIN obfuscated, can be read by forum staff]
Robert_669830
Unread post by Robert_669830 »
Hello
I have a Citroen C5 aircross and it has WAWE3
Since there are no more maps for it, it needs to be changed to WAWE4
It can't be changed. I need a license file.
My VIN: VR7**************[VIN obfuscated, can be read by forum staff]
Tomas1
x 11
Unread post by Tomas1 »
For NAC Wave 3, updating in classic mode is not possible, the certificates are expired.
borko
x 3
Unread post by borko »
Hi there!
I have Citroen C5 Aircross from 2019, and version 31 of software. I tried everything on this forum, with no success.
At the end, I called local dealer, and they said that they can update software and maps, but it costs around 100 eur (in Serbia).
Has someone gone that route? Will I then be able to update via Citroen app and USB in the future?
Tomas1
x 11
In classic mode updating is not possible.
Maybe the dealer uses another method (does not work in all cases)
Rjp1205
x 3
Unread post by Rjp1205 »
I have just checked the Citroen update app and it is now showing a version 42.03.33.42 as available. This is after it disappeared for a few weeks. I am downloading it now and will check the certificates to see if they are now valid before attempting update in my vehicle. I shall update on here once I know the info. Fingers crossed that it will work!
Rjp1205
x 3
Rjp1205 wrote: 17 May 2025, 21:42 I have just checked the Citroen update app and it is now showing a version 42.03.33.42 as available. This is after it disappeared for a few weeks. I am downloading it now and will check the certificates to see if they are now valid before attempting update in my vehicle. I shall update on here once I know the info. Fingers crossed that it will work!
Well that didn’t work out as expected. The certificates still expired on 03 November 2024. I shall visit by dealer again on Monday and see if Citroen have replied to the technical ticket that they opened for this issue. I shall keep up you informed of my findings. The main dealers only have access to the same software that we do via the update app so there is no point paying them any money to attempt it.
Dexter676
Unread post by Dexter676 »
There is easy way to fix it just buy a new car, and never buy from Stellantis again
508_gt
Unread post by 508_gt »
Rjp1205 wrote: 17 May 2025, 22:40
so they really republished the unusable version with broken certificates?
That is really really disappointing.
I thought that now finally they fixed it and downloaded it…
slhylcnn
Unread post by slhylcnn »
first of all hello dears,my car is citroen c5 aircross last month i changed my RCC to NAC WAVE3 so I can't update to the latest version of WAVE3 well I tried using the My Citroen app but I keep getting the error 'not compatible with the hardware'
Can you help me with on this issue ? thanks advance.
MY VIN IS : VR7**************[VIN obfuscated, can be read by forum staff]
myNAC wave3 information like is below
current version of my nac wave3
The version I want to update is as follows (remarked with red)
SterkeYerke
x 7
Unread post by SterkeYerke »
Our 508 will be going to the seller of the car (a garage that used to be a Peugeot dealership) for the update to the Wave 4 system. They claim to have found a way, but it'll take over 3 hours. Now the update itself is already quite large, so I imagine that alone already takes quite a while. Still I do wonder if it involves removing the clock battery from the system in order to trick it into thinking it's still before november 2024.
Tomas1
x 11
SterkeYerke wrote: 22 May 2025, 20:56 Still I do wonder if it involves removing the clock battery from the system in order to trick it into thinking it's still before november 2024.
Disconnecting the car battery resets the date (year 2007)
The update must be done with the BTA plug and GPS antenna removed from the NAC.
Deermand
x 4
Tomas1 wrote: 22 May 2025, 23:17
How do I access those connectors? How do I remove the radio?
SterkeYerke
x 7
I suppose that might depend on the car. But I'm glad to see there's at least some sort of solution!
Tetak
Unread post by Tetak »
GiveMeABreak wrote: 15 Dec 2024, 20:22
shocker wrote: 08 Dec 2024, 00:59 Hi, are certificates for wave 3 also expired? I'm on version 31. And can't install update suggested by peugeot app (42.03.33.42). It says firmware is not compatible with device. Is there any way to update wave 3 device now? Can you please help me out?
VIN: VR3**************[VIN obfuscated, can be read by forum staff]**************[VIN obfuscated, can be read by forum staff]**************[VIN obfuscated, can be read by forum staff]
It is a distinct possibility as there were 2 '31' versions, 31.08.05.86_NAC-r0 (May 2018) and 31.09.46.62_NAC-r0 (Nov 2018), so it is possible that the certificates have expires. Your issue is that that you may of needed one of these earlier versions to bridge the firmware from Wave 3 to Wave 4. The following is the latest update, but contains the map as well, so is a large download.
Firmware 42.03.33.42_NAC-r0 and Map
Shocker Licence File
Instructions for Updating NAC or RCC Firmware, Maps & Licences
Hi, i have Citroen C4 Cactus with 42.03.33.42_NAC-r0 system and i want to update maps only.
Do I have to copy whole 002315011619637877 folder on the root of USB or only its content. Also, where to put license Folder.
Thank you in advance!
