- x 8173
That head unit looks very similar to the one I fitted in the MX3 Zel. If it is the same then you can cycle through colour options and select the one you want. Green is available although mine is red to match the rest of my dash!
- x 8457
Wow! What a car
Full of very proper character
Zelandeth
- x 1613
There's definitely something amiss with the alarm system as it's currently working. Whenever the car has been sitting for more than a couple of hours you'll come back to find the light on the dash flashing.
Not sure if there's a lock contact that's a bit flaky so it thinks that someone has unlocked something. Further investigation required.
The terrifying disintegrating tyres from yesterday have been addressed.
Thanks again to the guys at The Garage for fitting me in so quickly.
Ended up with van tyres on this occasion as it was literally all we could find rapidly in the right size. Will see how it goes, but may not be a long term solution - the main goal short term though was just getting it safe to use.
That dash is definitely going to take a while to get old.
This definitely isn't an oddball collection is it?
Current fleet:
07 Volvo V70 SE D5, 89 Ford Thunderbird, 85 Sinclair C5, 84 Trabant 601S, 73 AC Model 70, 62 Rover 110.
- x 8457
No, not at all
Zelandeth
- x 1613
In my opinion this really is a smart looking car.
It doesn't really come across in photos I think how long it is though, especially for a two door coupe.
Few more observations have been made.
There is definitely some work to be done on the HVAC system. The air distribution controls appear to have no impact whatsoever on where the air goes. Thankfully it seems to be set to windscreen demist, so about the best possible outcome! I'd expect the blend flaps most likely to be vacuum operated in something of this era, so slightly easier to debug than overcomplicated electronics.
The air conditioning (unsurprisingly) doesn't work. I'd have been surprised if it did. I do wonder if the leak might be in this vicinity...
I suspect the service port has been leaking slowly over time, especially as the cap on the low side doesn't fit properly. Somewhat to my surprise there is actually some gas left in it - not much but something. So it might actually be viable to get that up and running again. Albeit obviously not on the original refrigerant given it would originally have been on R12 - though goodness only knows what's in there now.
I did very briefly have a low coolant warning ping up on the fluid level display (shown here during self test so you can see the indicators).
This appears to simply be a touchy sensor given that the level was spot on, and the light went off when I tapped the sensor on the expansion tank (it is a float switch). The tank is a bit rank to be honest and could do with a clean.
Looking at things more carefully, this car does actually have ABS - though the warning light for that appears to be noticeably absent when the ignition is first turned on and things go through the self test.
Why do I have a sneaking suspicion that someone has removed the bulb because the light would otherwise be solidly on? Might need to investigate that - though of course 80s/90s era ABS systems are notoriously difficult to diagnose and repair. The power braking part of the system is definitely working - I've not jabbed the pedal hard enough to know whether we actually have functioning ABS yet.
The new tyres definitely have made the ride firmer than it was, though I may experiment with dropping the pressure a bit compared to the spec given that the compound and sidewalls will be harder than the standard ones I'm sure.
Glad to report that the passenger's side of the dash has now been de-tatted.
Much better. I have a serious hatred of "stuff" stuck on the dash in my cars, so that absolutely had to go. Just glad they weren't screwed in place.
Then dip beam decided to vanish.
Need to investigate that tomorrow.
The automatic dipping system definitely isn't going to work given that the detector is currently in the boot as apparently the factory mirror fell off the windscreen at some point.
Yes, this had both automatically switching AND dipping headlights, in 1989.
That's not the reason for this issue though, as (when set to manual) the lights worked properly yesterday! Could be as simple as both bulbs having decided to die - if I'm really lucky. I doubt I'm that lucky though. Time for some digging...
Current fleet:
- x 8457
I fully agree Zel
- x 8173
I have to agree it is a very sleek looking version of the TBird, unlike the next evolution which you can see at:
https://www.carandclassic.com/auctions/ ... 4e69ed3d07
where I think they lost some of the style with that awful grill!.
On another point Zel I had an idea which you may like to explore. As we know the problem with driving a 'wrong sided' car is that when solo it is almost impossible to overtake on country roads as you cannot see ahead down the road from the nearside. Could it be possible to fit a forward facing camera to the offside mirror feeding a screen in full view of the driver - maybe one designed as a reversing camera ?
Zelandeth
- x 1613
Can't honestly say it's something I've ever found to be an issue. With how busy the roads around here are the opportunities to overtake anywhere other than on dual carriageway roads are basically non existent anyway. Doesn't matter which side of the car you're on. Just found before that backing off a little further generally gives sufficient visibility with a little patience.mickthemaverick wrote: 23 Nov 2026, 08:37 I have to agree it is a very sleek looking version of the TBird, unlike the next evolution which you can see at:
On another point Zel I had an idea which you may like to explore. As we know the problem with driving a 'wrong sided' car is that when solo it is almost impossible to overtake on country roads as you cannot see ahead down the road from the nearside. Could it be possible to fit a forward facing camera to the offside mirror feeding a screen in full view of the driver - maybe one designed as a reversing camera ?![]()
I'm rarely in much of a rush anyway and will tend to just go with the flow unless someone is being absolutely unreasonable. I always have to laugh when I see people madly dashing to overtake everyone - and end up sitting next to them a few miles later at the next roundabout/junction/set of lights. Can't imagine how unnecessarily stressful driving like that must be.
Current fleet:
Zelandeth
- x 1613
We have working dip beam headlights again. It wasn't the bulbs - though I've changed those now anyway as they were clearly pretty ancient and well worn. I will say that this is probably the easiest car I've ever changed a headlight bulb on - probably took me about 30 seconds a side.
Think there are three things going on here. Firstly is that I think one of the relays involved may be slightly sticky. Given the car has historically barely moved between MOTs, and was quite damp inside when arriving here that's not a huge surprise. I'll try to pin down which one it is (other than somewhere under the right hand side of the dash). Secondly is that the auto dip system simply doesn't work consistently without the detector plugged in, and will tend to default to main beam. Thirdly is that there's clearly a bit of a scratchy pot on the control for it.
Will need to pull this out and give it a clean tomorrow morning, and see if I can cobble together something to hold the detector in place on the windscreen - thinking dash cam mounting kit maybe.
Current fleet:
- x 8457
Well said ZelZelandeth wrote: 23 Nov 2026, 11:52
- x 8173
In our part of the world it is common to come up behind tractors pulling huge trailers at 15mph and enormous gravel lorries in and out of the quarries doing 20 or so. They are the ones that I overtake on a daily basis as they block out your forward vision along our B rosds completely. That is what lead me to thinking of my suggestion!
Zelandeth
- x 1613
Headlamp detector is back in position. Ugly but functional. I'll tidy it up when time is less of a pressure.
Half a cheap phone mount from Halfords and a woodscrew later, it was back in the windscreen.
The whole original mirror assembly turned out to mostly be held together by epoxy as the pot metal or whatever the stem is made of has fallen to bits. Problem for future me. I do want to get that sorted ideally as it also contains half the interior lights.
Have ditched the tacky looking steering wheel cover which had started to decompose and go sticky. Getting that off was a massive fight as it had clearly shrunk substantially over the years it had been there.
Much nicer to hold now, even if there are a few scuffed bits.
Oh, and I reset the oil change indicator as it was driving me absolutely nuts flashing at me in my peripheral vision. I'll hopefully actually get it changed next weekend, do have the oil in stock and should be a filter en route.
Being right next to the level indicators I kept worrying it was one of those blinking at me.
Helpfully all you need to reset it in this one is something like a paperclip - I'm guessing why there was one in the glove box!
There ends the list of what I've had time to look at so far.
Current fleet:
Zelandeth
- x 1613
First refuel done since it arrived - 27mpg over around 300 miles of mixed driving including a decent chunk of rush hour crawling in Oxford. I'll take that for something this comfortable with a 3.8 litre engine up front. If it hovers in the mid 20s I'll be pretty happy.
Very quickly attacked the headlights with some cutting paste today - they're going to clean up orders of magnitude more easily than the ones on the Volvo.
Before:
After:
Needs a bit more effort, but for all of ten minutes work I'll take it.
Reflectors aren't great, but it is what it is there.
Before:
After:
Current fleet:
- x 1484
How do the headlights get through an MOT test? Have they got E markings for LH dip?
Zelandeth
- x 1613
US vehicles I think you can usually get away with it as they have a flat beam profile with no kick up to either side.
I suspect something newer would need everything to be E marked etc, but being a 1989 car this will be tested as per the rules in 1989, which was far before that became a thing.
The Trabant needed the lights changing (or those horrible stickers on) because it had a beam with a kick up on the right side so would blind oncoming traffic - as the beam on this is flat it's just been declared to be fine as is I believe.
Tail end on the other hand required far more work. For a start, the US doesn't do rear mounted fog lamps, so that has to be added - further suggestions of the history of this car with Ford being present in the use of a for light switch from the Ford parts bin from that exact era.
In addition to that, the clusters as standard contain a grand total of two lamps. 5/21W lamps provide running lights, brakes AND indicators over in the US, the only other lamps being the reversing lights. Here what was originally the reversing lights have been repurposed with orange lamps as the indicators, with horribly tacked on looking lights in the bumper for reversing lights (which I think are actually from a Fiesta - have Ford branding on the lenses). I need to come up with a more elegant solution to that - especially as I really don't like the use of the reversing lights for this as they are far too close to the centre of the car in my opinion. They would have been much better using the extra fitted lights in the bumper as the indicators.
Current fleet:
