x 8171
Post by mickthemaverick »
That head unit looks very similar to the one I fitted in the MX3 Zel. If it is the same then you can cycle through colour options and select the one you want. Green is available although mine is red to match the rest of my dash! :)
x 8454
Post by CitroJim »
Wow! What a car :cool: Full of very proper character :D
Zelandeth
x 1611
Post by Zelandeth »
There's definitely something amiss with the alarm system as it's currently working. Whenever the car has been sitting for more than a couple of hours you'll come back to find the light on the dash flashing.
Not sure if there's a lock contact that's a bit flaky so it thinks that someone has unlocked something. Further investigation required.
The terrifying disintegrating tyres from yesterday have been addressed.
Thanks again to the guys at The Garage for fitting me in so quickly.
Ended up with van tyres on this occasion as it was literally all we could find rapidly in the right size. Will see how it goes, but may not be a long term solution - the main goal short term though was just getting it safe to use.
That dash is definitely going to take a while to get old.
This definitely isn't an oddball collection is it?
Current fleet:
07 Volvo V70 SE D5, 89 Ford Thunderbird, 85 Sinclair C5, 84 Trabant 601S, 73 AC Model 70, 62 Rover 110.
x 8454
Post by CitroJim »
Zelandeth wrote: 19 Nov 2026, 22:11 This definitely isn't an oddball collection is it?
No, not at all :-D
Zelandeth
x 1611
Post by Zelandeth »
In my opinion this really is a smart looking car.
It doesn't really come across in photos I think how long it is though, especially for a two door coupe.
Few more observations have been made.
There is definitely some work to be done on the HVAC system. The air distribution controls appear to have no impact whatsoever on where the air goes. Thankfully it seems to be set to windscreen demist, so about the best possible outcome! I'd expect the blend flaps most likely to be vacuum operated in something of this era, so slightly easier to debug than overcomplicated electronics.
The air conditioning (unsurprisingly) doesn't work. I'd have been surprised if it did. I do wonder if the leak might be in this vicinity...
I suspect the service port has been leaking slowly over time, especially as the cap on the low side doesn't fit properly. Somewhat to my surprise there is actually some gas left in it - not much but something. So it might actually be viable to get that up and running again. Albeit obviously not on the original refrigerant given it would originally have been on R12 - though goodness only knows what's in there now.
I did very briefly have a low coolant warning ping up on the fluid level display (shown here during self test so you can see the indicators).
This appears to simply be a touchy sensor given that the level was spot on, and the light went off when I tapped the sensor on the expansion tank (it is a float switch). The tank is a bit rank to be honest and could do with a clean.
Looking at things more carefully, this car does actually have ABS - though the warning light for that appears to be noticeably absent when the ignition is first turned on and things go through the self test.
Why do I have a sneaking suspicion that someone has removed the bulb because the light would otherwise be solidly on? Might need to investigate that - though of course 80s/90s era ABS systems are notoriously difficult to diagnose and repair. The power braking part of the system is definitely working - I've not jabbed the pedal hard enough to know whether we actually have functioning ABS yet.
The new tyres definitely have made the ride firmer than it was, though I may experiment with dropping the pressure a bit compared to the spec given that the compound and sidewalls will be harder than the standard ones I'm sure.
Glad to report that the passenger's side of the dash has now been de-tatted.
Much better. I have a serious hatred of "stuff" stuck on the dash in my cars, so that absolutely had to go. Just glad they weren't screwed in place.
Then dip beam decided to vanish.
Need to investigate that tomorrow.
The automatic dipping system definitely isn't going to work given that the detector is currently in the boot as apparently the factory mirror fell off the windscreen at some point.
Yes, this had both automatically switching AND dipping headlights, in 1989.
That's not the reason for this issue though, as (when set to manual) the lights worked properly yesterday! Could be as simple as both bulbs having decided to die - if I'm really lucky. I doubt I'm that lucky though. Time for some digging...
Current fleet:
x 8454
Post by CitroJim »
Zelandeth wrote: Yesterday, 01:38 In my opinion this really is a smart looking car.
I fully agree Zel :D Such a refreshing change from the usual crop of mobile bricks that bung up the roads and quite frankly offend the eye these days...
x 8171
I have to agree it is a very sleek looking version of the TBird, unlike the next evolution which you can see at:
https://www.carandclassic.com/auctions/ ... 4e69ed3d07
where I think they lost some of the style with that awful grill!.
On another point Zel I had an idea which you may like to explore. As we know the problem with driving a 'wrong sided' car is that when solo it is almost impossible to overtake on country roads as you cannot see ahead down the road from the nearside. Could it be possible to fit a forward facing camera to the offside mirror feeding a screen in full view of the driver - maybe one designed as a reversing camera ? :)
Zelandeth
x 1611
Post by Zelandeth »
mickthemaverick wrote: Today, 08:37 I have to agree it is a very sleek looking version of the TBird, unlike the next evolution which you can see at:
Can't honestly say it's something I've ever found to be an issue. With how busy the roads around here are the opportunities to overtake anywhere other than on dual carriageway roads are basically non existent anyway. Doesn't matter which side of the car you're on. Just found before that backing off a little further generally gives sufficient visibility with a little patience.
I'm rarely in much of a rush anyway and will tend to just go with the flow unless someone is being absolutely unreasonable. I always have to laugh when I see people madly dashing to overtake everyone - and end up sitting next to them a few miles later at the next roundabout/junction/set of lights. Can't imagine how unnecessarily stressful driving like that must be.
Current fleet:
