Zelandeth
x 1604
Unread post by Zelandeth »
So this will document the chaos, madness, tears and general day to day antics of my fleet. Generally focusing on the Xantia and 107, but probably with the odd appearance from my Saab and Skoda.
So today I finally got around to changing my fuel filter...got fed up of the new one rolling around the boot every time I went round a corner!
Bolts out no problem, cover off, filter came out stuck to cover - then dropped off it. Straight into the filter housing full of diesel. In just the right way to splash it all over me, the pcv hoses, front of the engine, radiator and intercooler piping.
So now both me and the Xantia stink of diesel. Guess I'll be out with the degreaser and the hose tomorrow!
...on the plus side, it no longer seems to be drawing air in.
On the minus side, took the 107 out this evening as it was reported to be "making a funny noise."
Yes, it is making a funny noise. The unmistakable drone of a wheel bearing on the way out. Ho hum.
Current fleet:
x 8406
Re: Oh well, know what I'm Doing Tomorrow!
I've done the same trick with a fuel filter Zel...
:twisted:
Be interesting to see what sort of a job a wheel bearing is on a C1. If you need a press to get the bearings out then give me a shout...
x 94
Unread post by citronut »
Zelandeth wrote: ...on the plus side, it no longer seems to be drawing air in.
and i suspect you have also fixed the clonking in the rear end as well #-o :-D :lol: :rofl2: :rofl2: :wink:
Regards, malcolm.
Zelandeth
x 1604
Will be reading up on that later I suspect.
Will let you know Jim. If it's the nearside front again I will be having some choice words with the car as that one was changed under warranty about two years ago.
...During which the dealer then fouled up the ABS which I ended up going around in circles for months getting sorted before eventually doing it myself! Wheel sensor not plugged in properly. You have to wonder if they ever looked at it when it bounced back to them...
Current fleet:
x 1489
I did that too first time I changed it.... after that I always cracked the lid off then inserted a screwdriver to hold the filter up whilst I lifted the lid off. Hindsight eh...??
Had the same trouble with ABS on my 307 last weekend after WB replacement - there was s bit of grit in the clip preventing the connector going home. Classic mistake on the modern ones is to fit the bearing back to front = no mag track for the ABS.... :roll:
Zelandeth
x 1604
Made a trip down to A5 Salvage today, so have finally got a replacement set of spheres for the front of the Xantia, get those on tomorrow and hopefully resolve the cartoon car bouncing of the front end. Also grabbed a replacement for my missing washer bottle cap as that was kicking me right in the OCD every time I opened the bonnet and was driving me mad.
Current fleet:
x 8406
Zelandeth wrote:Also grabbed a replacement for my missing washer bottle cap as that was kicking me right in the OCD every time I opened the bonnet and was driving me mad.
I know exactly what you mean Zel :twisted:
Zelandeth
x 1604
Glad I'm not the only one!
Current fleet:
x 3296
Madness is not a long drive away when you own a Citroen (or are a member of this forum!).
x 8406
Hell Razor5543 wrote: Madness is not a long drive away when you own a Citroen (or are a member of this forum!).
Or to find playing with Unix pleasurable :twisted: :lol:
(I do...)
Zelandeth
x 1604
Or own a Citroen, an 80s Skoda and a pair of Sinclair C5s?
Think I'm pretty well doomed!
Current fleet:
Zelandeth
x 1604
Front spheres done, nice when a job you haven't done in many years is as easy as you remember it being.
Citrobics session took longer than doing the spheres. Goodness what a difference!
...even though it is now obvious that the rears aren't fantastic. Not bad, but could be better.
*adds to the to do list*
Current fleet:
x 5673
Those "To Do" lists never seem to get any shorter, do they?
In my case it might help if I actually did some and could cross them off :(
Zelandeth
x 1604
To be honest, I don't think I'm going to let myself progress any further down the to do list for the Xantia until I actually do the one which is in big red letters on the to do list on the kitchen wall at the moment which is the timing belt etc as that's kind of important.
Current fleet:
x 8406
Zelandeth wrote:To be honest, I don't think I'm going to let myself progress any further down the to do list for the Xantia until I actually do the one which is in big red letters on the to do list on the kitchen wall at the moment which is the timing belt etc as that's kind of important.
It is.. When you want any assistance/advice you know where I am Zel...
