Passed the mot with a couple of advisories.
It's going back on the ramps this weekend and i'm going to partly dismantle the ram and get my micrometer on it.
I'll post any results next week.
Xantia noisy over bumps
peter306
- x 60
Re: Xantia noisy over bumps
Citroen GSA flat4 engine written off
Citroen BX 1.4 gone
Citroen BX 1.6 gone
Citroen Xantia 1.8 gone
Citroen Xantia 1.8 still living now 148 k
Citroen BX 1.4 gone
Citroen BX 1.6 gone
peter306
- x 60
Think i've found it
Can these be repaired, i remember someone mentioned a circlip.
The ram is a tight fit.
Citroen BX 1.4 gone
Citroen BX 1.6 gone
Citroen BX 1.4 gone
Citroen BX 1.6 gone
peter306
- x 60
gave the rod a clean
Citroen BX 1.4 gone
Citroen BX 1.6 gone
Citroen BX 1.4 gone
Citroen BX 1.6 gone
peter306
- x 60
Anyone.
I'm going to put a rubber o ring into the cup as a shock absorber. See ig that stops the noise.
Also asking in for sale or wanted.
Citroen BX 1.4 gone
Citroen BX 1.6 gone
Citroen BX 1.4 gone
Citroen BX 1.6 gone
peter306
- x 60
Eventually getting round to having a go at this, I think that once the bolt is tightened up it is pressing on the spacer before it gets to the thrust washers. If thats the case the bearings aren't as pressed as they should be.
I've got a new repair kit (Timken) coming and can get some shims of ebay, according to AI they are 30mm OD and 22mm ID.
Ive seen a method to measure the thickness of the required shim but can't find it, can anyone point me in the right direction, it involved measuring from the bearing to the spacer end but that's all I remember.
Citroen BX 1.4 gone
Citroen BX 1.6 gone
Citroen BX 1.4 gone
Citroen BX 1.6 gone
- x 2008
peter306
- x 60
Trailing arm bearings changed, still clunky but seems quieter when driving
Https://www.youtube.com/watch?v=@PeterBoothroyd-b5p
Citroen BX 1.4 gone
Citroen BX 1.6 gone
Citroen BX 1.4 gone
Citroen BX 1.6 gone
peter306
- x 60
Ignore that link, it says not available, I'll try again
Citroen BX 1.4 gone
Citroen BX 1.6 gone
Citroen BX 1.4 gone
Citroen BX 1.6 gone
Onlinemyglaren
- x 5688
Still not working.
peter306
- x 60
Ok, something doesn't like me.
Can admin delete my posts for today while I try and work out what i'm doing wrong
Citroen BX 1.4 gone
Citroen BX 1.6 gone
Citroen BX 1.4 gone
Citroen BX 1.6 gone
Onlinemyglaren
- x 5688
Done!peter306 wrote: Today, 15:25 Ok, something doesn't like me.
