Xantia noisy over bumps
peter306
x 60
Unread post by peter306 »
Happy to say my 2000 Xantia 1.8 16 valve 189,000 miles has now got a new MOT, emissions no problem steering rack boot was, first try was a not very stretchy rubber gaiter, stretchier one ordered and job done.
However there is still a clunking noise from the rear suspension, it's got new trailing arm bearings. Can old ram seals cause this problem, I ask as it seems to improve after a few minutes driving.
Rgds Peter
Citroen GSA flat4 engine written off
Citroen BX 1.4 gone
Citroen BX 1.6 gone
Citroen Xantia 1.8 gone
Citroen Xantia 1.8 still living now 148 k
x 2006
Re: Xantia noisy over bumps
Unread post by Stickyfinger »
Does it come up to level at the back when first started ?
Are the rams/pistons seated correctly ?
Can you trust the work done/rebuild when the rear bearings were replaced/was it done by a specialist Citroen garage ?
peter306
x 60
Hi Alasdair
yes it does but some fluid is leaking into the gaiter.
yes they are.
It was done by me following the methods on the forum, not the first time I've changed them.
Citroen BX 1.4 gone
Citroen BX 1.6 gone
x 1481
Unread post by xantia_v6 »
Are the ruuber bump stops present and correct?
peter306
x 60
Xantia v6
present but they are modified c5 ones.
And just to annoy me, got home, wound the window up and bang, cable broke
Citroen BX 1.4 gone
Citroen BX 1.6 gone
aerodynamica
x 216
Unread post by aerodynamica »
Are the rear subframe mounts in good condition? Anti roll bar 8x screws all tight and good?
Also! Some 'big' noises can be caused by small things like mudflaps occasionally hitting tyres e.g on turns, also the metal brake disk shield on each trailing arm can corrode and move about.. been there!
Graeme M
wurlycorner
x 271
Unread post by wurlycorner »
peter306 wrote: 24 Apr 2025, 17:19 Xantia v6
Sorry I can't help with advice on the knocking suspension issue, but after reading this, I think one of these may be appropriate?
https://theskidfactory.com/products/i-h ... RbVH3DFm_t
Iain
CX DTR T2 Safari (silver)
peter306
x 60
wurlycorner
I'll keep that in mind, hopefully they have different colours though :lol:
Why does spellcheck think i'm American. :rofl2:
I intend to check the things commented on tommorrow
Rgds Peter
Citroen BX 1.4 gone
Citroen BX 1.6 gone
peter306
x 60
Hello All,
Still the 1.8 Xantia
I have lifted the back and then dropped it, clunky noise in both directions.
Trying to attach a file (mp4) with the noise from rear of the car, not very successfully.
I believe it's the bearings that have lasted less than 2 years.
What is a good and reliable make for the trailing arm bearings.
Citroen BX 1.4 gone
Citroen BX 1.6 gone
wurlycorner
x 271
SKF used to do a kit for the trailing arm bearings on the Xantia (this was a long time ago though tbf!) and their bearings are excellent.
I used that previously and if that kit is still available (not sure?) then I'd recommend that.
Timken do one and they are also a reputable brand. https://www.ebay.co.uk/itm/177903231259
Iain
peter306
x 60
Hopefully the link works.
Took the trailing arm of and the bearings seem ok, no broken bits, cage intact.
this is the noise from the rear drivers side when I bounce the car up and down, same over bumps.
Citroen BX 1.4 gone
Citroen BX 1.6 gone
x 2006
Sounds like them (the arm bearings) to me.....but that is a guess from a sound
wurlycorner
x 271
Is that with no pressure in the rear suspension, or with the suspension still pressurised?
Iain
peter306
x 60
Alasdair, it does to me too but when i took the arm off they looked and felt fine.
Iain, engine running and in normal ride height.
Citroen BX 1.4 gone
Citroen BX 1.6 gone
wurlycorner
x 271
peter306 wrote: 26 Mar 2026, 23:32 Iain, engine running and in normal ride height.
That rules out some other options then and yep, leaves bearings as by far the most likely! :)
Iain
