Tales from beyond the grave AKA Dan & Emma's Black Xantia, pug 206HDi, Daniel's 206 Verve 1.4i, GTi180 plus XUD9TE 206!!
- x 8440
Re: Tales from beyond the grave AKA Dan & Emma's Black Xantia, pug 206HDi, Daniel's 206 Verve 1.4i, GTi180 plus XUD9TE 2
That's superb news Dan
ekjdm14
- x 273
Well pleased to once again be "back in Black"
Heater isn't all I remember it being, although I think that's to do with the foam being missing off the blend door & recirc door judging by the click/knock they make on closing rather than the soft thud one normally hears. Other than that all's well so far & nice & comfy once again (spits on Focus seat)
EDIT-: just popped out and swapped the bodged positive battery cable to a better bodge as the body electrics were getting iffy & starter didn't engage 100% Got a nice quick-connect terminal on there now too.
'95 Xantia LX 1.9D-auto, Black, 123k
'96 ZX SX 1.9TD, White, 90k
'12 Mini freebie project
ekjdm14
- x 273
With Black now pronounced "reliable" once more, I took the opportunity to drop the sump off the Bin-i this afternoon. As predicted the failure was again on #3, although not nearly as bad this time. Bearing hasn't spun this go around, and has basically just eaten the upper shell leaving the lower one with light scarring.
From the wear pattern (very even across the upper shell, probably taken over 10 thou off it though as it's to the copper already but *not quite* as bad close to the parting lines & lower shell same pattern and almost run-able if it hadn't had bits of the upper pick up on it), taken along with the previous failure on that cylinder, I'm hopeful that the rod itself isn't deformed (ovality in the rod bore would tend to pinch worse at the parting line and from what I've read this pattern is almost textbook injector failure symptoms.
Why I didn't hear it "nailing" at idle/free revving (and why it lasted fine on the driveway and died after only a couple of pulls under boost) would be thanks to the ECU having the ability to correct slightly for individual injectors at idle for "smooth running" and rail pressure being lower too... So basically I think with the crank cleaned up and the one shell replaced again (it's having one of the good used ones this time!) it'll need the injectors taken in and tested/refurbed/replaced and maybe will manage to make it more than a mile down the road finally. Be pretty nice as it's got MoT to take us through till end of Feb. so can keep the salt away from Black!
- x 8440
This remains rather an interesting and intriguing mystery on the No.3 big end bearing fails on the Bini Dan..
I wonder if the journal has worn oval or perhaps the bearing housing in the block and/or the bearing cap has become distorted as a result of the original bearing shell spin? Getting a micrometer on it might be revealing.
More intriguing that it's the upper shell that's suffered more... Logic would say the more wear would be on the lower shell based on the belief there's more thrust loading with the piston descending on the firing stroke.
We know the failure was not due to a lubrication failure due to blockages/restrictions in the oilways so maybe the bearing failure was due to too-tight a clearance in the bearing leading to indirect lubrication failure. A journal that's worn oval or distortion in the housing could conceivably cause this... Time to get the plastigage out...
It could still be due to a partial blockage in the oilway leading to that journal... A bit like a person suffering furred-up arteries...
I'm fascinated by this and I trust you don't mind me thinking out loud on the possible causes...
ekjdm14
- x 273
On the final point, of course not Jim. Your thoughts (and anyone else who happens to chime in) are more than welcome, it's good to have some other human input to go along with my own research & AI's responses.CitroJim wrote: 16 Nov 2026, 13:39 This remains rather an interesting and intriguing mystery on the No.3 big end bearing fails on the Bini Dan..
Sadly don't own one myself, but will have a word with a neighbour and see if he's got one I could borrow (as well as a telescopic to check the rod housing
Brain fart on your part I fear, Jim. Thrust on firing stroke loads upper shell on a rod![]()
Clearance checked in-spec on reassembly, but only in a couple of spots. If mic isn't available then will plastigage in as many different positions as possible
Possibly, there was good amount of oil on the bearing but will double-triple check anyhow
It's from AI that I got the idea of it being the injector TBH, because my first thought (and "it's" first suggestion) was distortion to the housing BUT the wear pattern from a distorted rod would tend to pinch at the parting line relief area & chew the bearings up worse on the ends, whereas the upper shell is fairly evenly wiped out, maybe a little better either end.
- x 8165
This is in my regular auction house's sale on Wednesday Dan
https://www.i-bidder.com/en-gb/auction- ... f900ca8c8e
- x 8440
Yep, you're right I got it wrong on the firing stroke thrust Dan
Doh!
- x 8165
In fact, thinking about this I believe the upper shell takes the force on 3 out of the four strokes, only when the crank is pulling on the piston rod, ie induction, does the lower shell take the force?:
Induction - crank pulling piston - force on lower
Compression - crank pushing piston - force on upper
Combustion - piston pushing crank - force on upper
Exhaust - crank pushing piston - force on upper
That's my thinking, right or wrong?
- x 8165
While thinking about the above another thought ocurred to me, just thinking aloud. If number 3 piston has a 'higher top' due to a fault of various possibilities, it would get higher compression than the other cylinders and hence produce more force on combustion? Corrosion, over long rod, thicker lower shells, misshaped head are all possibilities?
ekjdm14
- x 273
Correct, 3/4 on the upper Mick. All good suggestions on other reasons for failure, and indeed the history of this engine indicates "rebuild with timing chain, bearings, piston & rings" (note piston singular). With that being said, it has run over a year and around 14k miles since that was done.
Definitely need to check the injectors as it'd be silly not to, and will see if i can borrow a mic, that auction one is a good price but I'd need a 2" one for this crank.
ekjdm14
- x 273
Oh, in other news, Ryan has only gone & bought a 1987 Nissan Sunny 1.3L...
He'd had some cash burning a hole in his pocket for a few days when this popped up on his marketplace a few miles down the road for £500. It's been sat for 21 years judging from the last MoT certificate, but the body is surprisingly solid for an 80's Nissan with just rear outer sills needing patched, plus it's done about 60k miles and is really straight, couldn't find a ding or dent on it. Engine rotates, brakes are free, tyres hold air the lot. The fella selling it has started cleaning up some bits and undersealed the floor & had started on getting it running but a couple of bolts broke off in the thermostat housing.
All in all, doesn't look to need a whole lot to get back to life. Sills welded, exhaust back on, reassemble the interior bits that are out for cleaning/checking rot spots and go over the engine/fuel system she should be good to go. I'd probably replace the tyres too, although they aren't all cracked up and have good tread.
Bit different, but I like it, the lad's got good taste and a good eye for a bargain too.
- x 8165
Plus the fact that in a few months it will become tax and MOT exempt!! Result.
ekjdm14
- x 273
There is that too
Probably will chuck it through an MoT anyway, and tax exemption starts from April the following year (2028) but still makes things a little sweeter.
