x 2356
Post by MattBLancs »
I can't help but wonder what you'd hear if typing on that keyboard....
....with that 6.35mm jack plugged into a guitar amp! :rofl2:
(May be terminally detrimental to keyboard and/or amp, no doubt!)
x 8412
Post by CitroJim »
MattBLancs wrote: 17 Oct 2026, 22:21 I can't help but wonder what you'd hear if typing on that keyboard....
You've got me curious now Matt!
Zelandeth wrote: 17 Oct 2026, 21:57 Well I don't see any immediate red flags. I don't know where my proper capacitor reformer box is (a sign of how long it is since I've played with any valve gear), but the big high voltage DC reservoir caps reformed fine with zero leakage up to the ~40V I can coax out of my bench top supply. Generally I've found if they're going to be leaky they'll do it as soon as there's any appreciable voltage there. So they're probably fine.
Yep, that's a good first move to check the PSUs Zel... They do have a tendency to go off with some very impressive bangs and flashes when first powered after long disuse otherwise!
Zelandeth
x 1607
Post by Zelandeth »
Sadly doubt you'd hear anything I believe. The voltage for the signal from the guitar is generated by the strings passing through the magnetic field from the pickups if my memory is correct. So given this thing only consumes rather than generates voltage, aside from it likely acting as a lovely antenna to pick up 50Hz mains hum, you'd probably hear nothing. Only three conductors, power, ground and bidirectional serial data.
I didn't realise quite how advanced these things were for their time. 3K of RAM was by late 70s standards a usable amount for a basic computer, and 8K of ROM is quite a chunk. There are essentially two processors on board, one for all intents and purposes doing the "housekeeping" and one entirely dedicated to handling the display itself. Block diagram below is from the service manual.
Quite complex for something launched in 1978, and really is a computer in its own right. Fact they managed to cram that all onto something not much bigger than an AT class PC motherboard is really pretty impressive honestly. Equally impressive to me is that they had implemented a non volatile RAM to save option settings (all done in software, no hardware DIP switches) without needing a battery. If only that had become the normal practice it would have saved me a bunch of hours repairing boards dissolved due to batteries that have leaked.
Apparently a few more boards for the PDP have now been tracked down. Including the RL02 controller, and interestingly a DEQNA network card. Which is actually AUI compliant - which can then be relatively easily converted to modern ethernet. So it's entirely likely I can get this thing actually on my local network. That would be quite something, and definitely be useful for getting software on/off it for experimentation purposes. Which let's face it is basically what this is all about. Definitely be the oldest thing I've had on there - I think a 286 PC from 1988 has until now had that record. I'm sure configuring the network stack on the PDP won't be at *all* confusing and have me questioning my sanity when I get into that.
Current fleet:
x 8412
Post by CitroJim »
Well, at least there's no risk from viruses and scams with a PDP-11 on the network Zel!!!
Zelandeth
x 1607
Post by Zelandeth »
With the modern internet falling apart today, I decided to look at something less complicated!
Not worrying too much about cosmetics right now, but it looks like it will actually clean up a lot better than I originally thought.
For now though I'm more interested in the electronics.
Despite the external state, internally it's actually pretty clean internally. Honestly far cleaner than plenty of kit half the age I've worked on.
The whole computer part of the machine is on one board - and is actually based around an 8080 CPU - which is kind of ridiculous when you consider the sort of things that people might have been connecting terminals to in 1978 when this was launched... wouldn't be entirely unexpected for the host computer to be based around an 8080.
Very clean board.
The riser there is part of an expansion option which also includes an additional full size board.
Plus a custom back panel with an additional interface connector.
This whole bundle of bits is a Retro Graphics VT640 upgrade kit.
Which for the time was actually quite capable, expanding the abilities of the terminal to include 640*480 pixels of bit mappable graphics. Obviously this also needs the software to utilise these capabilities, and I doubt it will be something I'll be able to utilise, but if I do get hold of something that can use it it will be great to have.
These things are actually pretty bomb proof if they've not been physically smashed to bits or drowned into a corroded mess. Nevertheless I didn't want to just blindly plug it in and cross my fingers. One thing I could see at a glance was a pair of pretty massive capacitors in the power supply - at the very least I wanted to make sure they weren't shorted and at least try to gently reform them rather than just waking them up from probably a forty year slumber by brute force. That way in my experience is a route to loud bangs. These look like they could make quite a bang.
The case design is largely tool-less, four screws and several pull clips are the only things you need to remove from the bottom of the case and the whole chassis can be lifted out, and the power supply then extracted to be taken to the bench.
Quite surprising to see something from this era with a switching supply rather than giant heavy transformer and linear supply generating enough heat to supply a small town. Guessing this is part of the reason that the whole unit is actually a lot lighter than I expected. It is still a pretty chunky unit though - especially for the ~100W it's expected to provide. From what I've read though it is actually quite overrated though to ensure headroom when expansions are fitted. Especially keeping in mind that everything here is entirely passively cooled.
These caps are rated to 200VDC, which is more than I can easily supply on the bench - but I figured reforming and checking for leakage at around 40V was better than just slamming them into duty from nothing.
This seemed to go smoothly. One seemed to have a little more leakage than the other but both within what I'd consider reasonable limits.
Rest of the caps in there are far less likely to turn properly violent in the case of failure, and doing some in circuit checks didn't show any that were obviously shorted. So figured it was time to go for the smoke test.
This was... entirely undramatic! No smoke, just a faint and initially slightly unstable 15kHz whistle which told me that the line stage was somewhat to my surprise running. And we did have a little noise on screen (which is green apparently rather than the white I was expecting). Plugging the keyboard in resulted in a beep when powering on as well, though I didn't have anything on the display and the system was otherwise unresponsive. This is still good news though. I'd proven that the system was fundamentally "working" sufficiently well that the CPU is alive, is properly coming out of reset, is executing code from the (quite extensive 8K of ROM), the system is actually booting into at least the self test routine, and that the serial communication line with the keyboard is working (the speaker is in there not on the unit itself). Fact we've had some life on the screen also tells me that the EHT side of things is working.
Returning to things after dinner though it was as dead as a doornail. As far as I can tell the power supply has decided to identify as a door stop. It's *completely* dead and not even trying to start (no the fuse hasn't blown and it's not just the switch). So my first port of call is going to be the startup circuit.
Back on the bench.
While I was in there I reflowed a bunch of suspect looking solder joints and changed a couple of slightly maybe suspect caps (I had the value on hand so just figured on it as insurance), and swapped out the 7812 12V regulator which runs the startup circuit to kick the whole supply into life.
This is as far as I've got. The design of this thing makes it a bit awkward to test things as it all slots together into edge connectors which are deeply buried in the chassis, rendering pretty much everything inaccessible. If the power supply is still sick when I plug it back in I'll need to rig up a dummy load to test it on the bench (NEVER run an early switch mode supply like this without a load unless you're absolutely certain that it's designed to, as they often need a minimum load to regulate properly). Hoping that won't be necessary as probing a live switching supply always feels rather precarious. On the plus side schematics do exist and it's discreet enough that it is actually serviceable rather than just being one mysterious black box. On the downside, the board has no silk screen, so actually following it relative to said schematics is kind of tedious.
Let's see if I can make any more progress tomorrow evening.
Current fleet:
x 8412
Post by CitroJim »
It quite beautifully built Zel and I'm sure it'll soon respond to to your desire for it to be functional again :)
Zelandeth
x 1607
Post by Zelandeth »
No progress on the VT100. I need to rig up a dummy load and get the thing on the bench for some live testing to try to find out what's happening and what isn't.
All the caps involved in the start up and soft start circuit have been changed, the 12V regulator involved has been changed and I've verified continuity between that circuit and the controller IC. More investigation needed - based on actual study of the schematics and testing rather than just following a hunch. Not that I've not fixed quite a few things based purely on that over the years!
Current fleet:
x 8412
Post by CitroJim »
Zelandeth wrote: 22 Oct 2026, 22:24Not that I've not fixed quite a few things based purely on that over the years!
Me too! Especially given some of the old, arcane kit I deal with :-D I'd say it's very much more skill and experience rather than a hunch :wink:
Zelandeth
x 1607
Post by Zelandeth »
All right ya git. Back on the bench.
Trying to follow something this complex (thank god it's only a single layer two sided board) without any silk screen is a pain in the tail. Non starter when it's live basically as there's ~300VDC across several bits of the PCB so swiveling it around to follow things isn't happening.
I did hook up a dummy load and do some live testing to see if I could find anything glaringly obvious amiss. The most obvious thing was that as I suspected, the startup circuit was doing absolutely nothing. Notably as well there was a distinct lack of power getting TO the startup circuit...which would definitely explain why it wasn't starting.
A bit of careful tracing of the PCB (after waiting the 15 minutes it takes those huge HT DC caps take to discharge) revealed more fun. What the fluff are you then?
Not on any of the schematics or the component layout, that's what you are. That to me looks awfully like a PCB mount fuse. A fuse which is doing a good impression of open air from an electrical standpoint. A little more investigation reveals it to be in the position shown by the red X in the diagram below.
Which would indeed explain why the startup circuit is doing naff all.
I have during the initial debugging replaced Z2 and C33. The four diodes in the bridge test fine on the meter, but as they are just garden variety 1N4004s I've now changed them anyway as a precaution in case one of them is breaking down and going short under load. My finger is pointing at either the regulator or the capacitor likely having been the guilty party though.
I'll try bridging that via a sacrificial low wattage 1 ohm resistor and see what happens in the morning and see what happens. I'm not doing it right now as if it goes bang and trips the breaker that would require me to go outside in the pouring rain and move two cars to get into the garage to reset it!
If this does make it work I will feel very vindicated in my original hunch though.
Current fleet:
x 1074
Post by Rp0thejester »
I actually thought your initial photo yesterday was of an old microwave, then I saw the back of it and thought no, it's an old TV. What the hell is that thing!!!!
Zelandeth
x 1607
Post by Zelandeth »
Rp0thejester wrote: 23 Oct 2026, 23:43 I actually thought your initial photo yesterday was of an old microwave, then I saw the back of it and thought no, it's an old TV. What the hell is that thing!!!!
It's a VT100 data terminal.
Wikipedia link
Basically at a very simple level you plug it into a serial port and use it to interact with a computer system at the command line level.
I'm going to be putting together a DEC PDP-11 in the not too distant future, and the sole means of interacting with that will be text to and from a serial port.
Current fleet:
x 8412
Post by CitroJim »
Good progress Zel and yes, C33 has to be a good candidate... The 7812 regulators are usually pretty robust and protect themselves quite well usually...
Keep us posted ;)
Zelandeth
x 1607
Post by Zelandeth »
Well would you look at that?
My original hunch that our problem lay in the startup circuit was right. Not entirely sure what caused that fuse to blow, but leakage in C33 before it had a chance to reform seems a likely candidate. Especially as the supply did work the first time we tried it. Current draw in there is in the region of 0.3A now. That fuse is getting moved off the board so it's far less of a pain to change if it ever needs attention in the future.
So we now have a flashing 4 on startup.
This indicates a keyboard error. Which ties in with the fact that it's not responding to any keyboard input.
However...
It is quite happy to display data which is fed into it externally. So we definitely have more working now than not. Definitely progress.
Current fleet:
Zelandeth
x 1607
Post by Zelandeth »
Update. Provided by the device itself.
Using suitably era appropriate test equipment to feed it data of course.
Keyboard is a bit of a pain. I totally failed to spot this wasn't actually a real VT100 board initially - it is incredibly similar externally.
Shape is absolutely spot on as can be seen by how well it tucks under the front of the unit.
The only tells are an additional "Rept" key and one legend on the status LEDs reading "Off line" rather than "Local."
Internally though the circuitry is using a totally different chipset to the DEC one. It's clearly still using a two wire serial interface, but is likely using totally different scan codes.
This is a shame as it's in near immaculate condition and feels quite pleasant to type on. There is the added fun that VT100 keyboards are hard to find and seem to change hands for daft money - not least because people seem to love gutting the electronics and turning them into "retro" standard PC keyboards. So we may well need to look at a more creative solution. Will need to apply some brain cells to this. The usual solution is building an Arduino based converter to utilise a standard PC keyboard. We may need to do something similar - but ideally doing the conversion between whatever data this is spitting out and what the terminal expects. At the end of the day it's a pretty simple serial data stream so shouldn't *in theory* be all that difficult...Or possibly end up using the existing key switch matrix and a converter - trickiest bit in using the existing circuit would be not knowing what it's expecting in terms of the inbound data from the terminal. More thinking needed. However paying £300 for a keyboard isn't happening!
Current fleet:
x 8412
Post by CitroJim »
It's truly awesome to see that VT100 well and truly alive again Zel!
There's something absolutely magical about a green screen :cool:
Now to get that keyboard sorted; I'm sure you can ;)
