x 2356
Unread post by MattBLancs »
Huskyxantia wrote: 06 Oct 2026, 18:14 Because these are temporary spikes causing the issue might be worth checking the earth locations?
Will have a look at earth points, at some point soon! :)
Found a thread talking about the amp shutting off as a "self protection method" in the event of a speaker channel going open circuit. Poor connection at amp and at speakers / door jambs. Seems plausible.
More pressing, the car has given
Engine fault, repair needed
Message, SERVICE light on and horrible limp mode (refusal to rev over 2000 rpm and what feels like about 30 bhp instead of 150!
Quick read of faults this morning before commute to the office
x 2356
Engine faults
1
1
2
2
3
3
BSI faults
BSI faults
BSI faults
Power steering overheating, ages ago!?!
PAS
PAS
x 2356
Rate of engine oil dilution excessive,
Estimated dilution rate: 10%
I'm fairly sure it's about 6 litres of oil in the sump, so 600 ml of diesel from failed regents!? Seems a lot. Not aware of any other mechanisms for oil dilution.
Oil change at the weekend as first step.
Think "last 10 regents average" was something like 180 km, not ridiculously short.
All thoughts welcome! :)
Huskyxantia
x 920
Unread post by Huskyxantia »
My 308 was erratic for most of the hot weather with regen stuff , since the weather has gone back to normal its only done 1 in about 8 weeks.
When they need a service they can regen or fail to do a proper one , give the car a full service, if you can use that dpf cleaner you spray down the dpf then give it a run ( instructions on can plus videos on youtube)
:-D
x 8417
MattBLancs wrote: 12 Oct 2026, 19:52 Rate of engine oil dilution excessive,
Just a few potential reasons Matt. Bad injectors, worn rings, worn bores, worn pistons.
I'm intrigued to know how the system determines this... Oil level perhaps?
x 2356
CitroJim wrote: 13 Oct 2026, 08:26
Not raving about that list of possibilities! :rofl2:
Quick googling at lunchtime:
Yep, high oil level + number of incomplete regen attempts is apparently the trigger.
Oil change, reset codes and see how it behaves is my plan.
x 1492
180km is pretty short for regens ; it probably needs the DPF flushing out to get rid of the ash.
x 2356
RichardW wrote: 13 Oct 2026, 20:59 180km is pretty short for regens ; it probably needs the DPF flushing out to get rid of the ash.
Good thinking, will investigate cleaning this out.
Replacements are £600 on Autodoc! :eek1:
Huskyxantia
x 920
:-D
Huskyxantia
x 920
My 308 hasn't done the risk warning now in over 600 miles, I did 2 weeks ago add 20 quids worth of the supreme diesel that all new stuff that came out several yr ago that most avoid due to its price, you watch i get the warning pop up today lol
:-D
x 2356
Huskyxantia wrote: 17 Oct 2026, 06:46 https://ebay.io/m/WaF7SV. ?
Thanks Husky - unfortunately that's not the right type - with mention of Euro 5 I suspect that's first generation 308. On my 2016 model it looks like this:
Berk for scale
Berk for scale
DPF one long piece, not "half and half" like that one.
Lots of rusty fittings tackled today, DPF off the car. Clean out tomorrow hopefully
Huskyxantia
x 920
Looks like a torpedo
:-D
x 2356
Huskyxantia wrote: 17 Oct 2026, 18:06 Looks like a torpedo
It's a big heavy lump! I thought DPF and catalyst were both in this unit, but there's another "lump" in the exhaust further up towards the engine - perhaps that's the catalyst?
Adblue injector clip is retained with a 4mm alien head bolt, not rusty (stainless I think) but not budging at all, so to tackle off the car.
Oil drained. Oil filter stupid tight, not defeated that yet. Need to find my strap oil filter wrench (it's rare I need to use it, I can normally get the filters off by hand - not this one!
Huskyxantia
x 920
Sounds like that filter hasn't been changed for a while and has been getting hot top , great job on what you have done today
:-D
x 2356
Huskyxantia wrote: 17 Oct 2026, 18:54 Sounds like that filter hasn't been changed for a while and has been getting hot top , great job on what you have done today
Yep, pretty sure it's original item. 119,000 miles covered.
In comparison, the blue 308 SW was at 156,000 miles and DPF hadn't played up for me - again as far as I know that was original unit. Perhaps the red 308 has done a great many more short trips and hence greater amount of soot "per mile" over it's life. Ah well, hopefully it'll respond well to a cleaning attempt [-o<
