1999 Peugeot boxer help
TomTomA
Unread post by TomTomA »
Hi,
My oil vapour hose has a slight split at the top and needa replaced. I believe the OEM number was 1192E1. For the life of me I can't find this anywhere and my mot is due. Can anyone help or point me in the right direction. It does leak a bit of oil so it will fail the MOT.
Thanks in advance.
Tom
x 8121
Re: 1999 Peugeot boxer help
You should be able to seal it with self amalgamating tape to get through the MOT and then replace it when you can find one! :)
penners11
x 5
Unread post by penners11 »
What is the red wire for zipped tied to the pipe? I may have very similar I got for a Xantia years ago but never fitted it.
It's not exact, it looks like the ends are different sizes, correct me if I'm wrong. The pipe I have (if I can find it) both ends are different sizes. As mick says, you should be able to seal it temporarily with the tape.
TomTomA
mickthemaverick wrote: 30 Sep 2026, 17:10 You should be able to seal it with self amalgamating tape to get through the MOT and then replace it when you can find one! :)
Hi mickthemaverick,
Thanks for this but with the split being at the very end of the pipe I am unsure if it will hold. I will definitely give it a try though. Smart, I never thought on that so thanks again. Much appreciated 👍🏻
TomTomA
penners11 wrote: 01 Oct 2026, 14:44 What is the red wire for zipped tied to the pipe? I may have very similar I got for a Xantia years ago but never fitted it.
Hi penners11,
I am unsure what it is for but will be putting it back there 😂. If you do happen to find that pipe could you send me a pic or the part number if written on it please. Thanks for your help with this also. Ohhh I am unsure if the pipes and sized different at each end but will check it out later today 👍🏻
penners11
x 5
Not sure how you post photos on this site, I will have to look in the help section for that after I have taken photo's. Or DM me and I'll send them direct but again I've never done that either which require help files again if your interested.
x 8121
A guide to posting images is here:
viewtopic.php?p=516529#p516529
penners11
x 5
Hi, as you can see the pipe has a re enforced plastic around part of it which could be warmed gently twisted or manipulated to fit or taken off again with I bit heat.
Just let me know if you could use it. I don't want paying just a donation to the forum would surfice.
It was for a 1.9 xzantia diesal engine breather, part nos are faint but it was from citroen.
TomTomA
penners11 wrote: 04 Oct 2026, 13:50 Hi, as you can see the pipe has a re enforced plastic around part of it which could be warmed gently twisted or manipulated to fit or taken off again with I bit heat.
Hi penners11,
Thanks for the reply and offer but it is to big for the fitting. I will double check this today and get back to you though 🤞🏻
Tom
