Touch screen update keeps showing "Version not compatible with hardware" error.
This is the Connected NAV system.
Main Features: It is a fully integrated Telematics System featuring CarPlay, Android Auto, Real Time Services, Voice Commands, High-Res Display, 3D Navigation, Bluetooth Hands Free & USB. 2 versions of the system are available NAC (Navigation Audio Connectée) and RCC (Radio Couleur Connectée) or Connected Colour Radio, which does not have the Integrated Navigation or Live Services.
dbozhinoski
Re: Touch screen update keeps showing "Version not compatible with hardware" error.
Unread post by dbozhinoski »
It finally read the updates, but unfortunately, now i got this error:
Update 001315031692686757 has failed.
CitEc4
New User
Unread post by CitEc4 »
rui_saraiva wrote: 07 Sep 2026, 00:24 Copy this license key
https://majestic-web.mpsa.com/mjf00-web ... D4D1E2992A
to a "\license" folder in a USB flash drive with the 44.07.33.32_NAC-r0 firmware version (UpdateID 001315031692686757).
Thank you so much for these files. I’ve been struggling with this update for a while. I finally got it done following your instructions. Why would Citroen not do this themselves!
Anya1st
Unread post by Anya1st »
@rui_saraiva
I have check the vin on your page and it comes up with wave4 but still having issues. Here’s the steps I have done.
Bought a new 64gb usb.
Inserted usb and formatted it to FAT
Downloaded 44.07.33.32_NAC-r0 to computer from your page.
Transferred download to usb.
Now when I plug the usb into the car it now saying unable to read data.
Please tell me where I’m going wrong. Im lost and banging my head now
RobertBu
Unread post by RobertBu »
rui_saraiva wrote: 10 Aug 2026, 14:04 @RobertBu: That's probably a NAC_EUR_WAVE4 (but you can input your VIN on my page to verify it) and those updates can be used in any Citroën, DS, Opel, Peugeot and Toyota with that system.
The "version not compatible with hardware" is a generic error and rarely related to hardware incompatibilities...
You also need to identify your current firmware version: Hours/cog, OPTIONS, System settings, System info, View.
* With a NAC_EUR_WAVE4 system, you'll get that error if you already have a version newer than 44.06.44.22_NAC-r0 (the version offered by the Opel Update/MyOpel), such as 44.07.05.22_NAC-r0 or 44.07.33.32_NAC-r0 - ignore the official update software, you can't downgrade the firmware anyway;
* With a NAC_EUR_WAVE3 system, but with a 44.0x.xx.xx firmware installed, the above applies, but you are offered the 42.03.33.42_NAC-r0 firmware and there are a bunch more of newer firmware versions.
What is your infotainment system and what is your current firmware version?
Hello @Rui
This is my current system version, I wanted to use E-routes that my car it have built in, but somehow is requesting to have an update in order to work
My current version is 44.02.16.52_NAC-r0, i want to update to the latest one but I could not do it by MyOpel app, I also read the other forum, but its hard to see a stept by step instructions there.
I have done the checking with my VIN and downloaded the file and extracted to my USB flash drive with 32 gb in fat32.
What should I do next?
After this I will update also the MAPS as well.
Thank you in Advance!
rui_saraiva
x 63
Unread post by rui_saraiva »
@Anya1st: That error means your USB flash drive wasn't FAT32-formatted. Only recent versions of Windows are able to FAT32-format partitions larger than 32 GB - you only see NTFS and/or exFAT options, neither compatible with the car. You can use 3rd-party software to do that, such as Rufus.
@RobertBu: You don't need to update the firmware to use any of the connected services, regardless of what the app says. You also don't need to update the firmware to update the maps. You can try to update the firmware without the license key on the USB flash drive (the car will try to use any of the available connections - internal eSIM, WiFi or Bluetooth tethering - to verify the license). If it fails with the generic "version not compatible with hardware" error, press that "Exportare configuratie" with the flash drive inserted and post here the name of the files "instkey_xxxxxxxxxxxxxxxxxxxx.xml" or "packageslist_xxxxxxxxxxxxxxxxxxxx.txt. Those "xxxxxxxxxxxxxxxxxxxx" are your UIN (Unique Identifier Number) and are needed to manually download the license.
Regards,
Rui Saraiva
All NAC, CRONY2, AIO, RCC & RCE updates: https://sites.google.com/view/nac-rcc
sleenheer
Unread post by sleenheer »
Hi,
same problem here, Citroen E-C4 2021. Used VIN number on site.
Downloaded from app, but will not install.
Downloaded 44.07.33.32_NAC-r0 22 Aug 2023, but the license key which i use is from the App.
Can you tell me where i can get the license key for this version, as the "error" persists. The key provied earlier in this thread does yield same issue.
"Incompatible"
Thanks!
rui_saraiva
x 63
@sleenheer: Whats is the filename of the license from the app?
Regards,
Rui Saraiva
sleenheer
license_0D010F1EB9D4D9607FCC_001315031671116172.key and this is the version it gives for system: PSA_ovip-int-firmware-version_44-06-44-22_NAC-r0_NAC_EUR_WAVE4
rui_saraiva
x 63
@sleenheer:
You could download the license for the firmware version 44.07.33.32_NAC-r0 (UpdateId/MediaVersion 001315031692686757) and for your car (UIN 0D010F1EB9D4D9607FCC) from:
Code: Select all
https://majestic-web.mpsa.com/mjf00-web/rest/LicenseDownload?mediaVersion=001315031692686757&uin=0D010F1EB9D4D9607FCC
Regards,
Rui Saraiva
sleenheer
Maybe Lifesaver is overdone, but comes close!
