Well worth adding the extra layer on the inside by clamping it in place, then staple from the other side and bend ends over to hold the tarp. A coat of glue will strengthen it even more!!
- x 8124
Yeh, you can't see it but it has a corner misssing that I used on the C5.
- x 8406
No, have never felt the need for one as yet. So I'll take you up on that offer Mick. Thank youmickthemaverick wrote: 26 Aug 2026, 11:29 Have you got a hot staple gun Jim? I can't remember. If not you could bring it here and we-ll sort it.![]()
Thanks Richard, that's good to know and some valuable informationRichardW wrote: 26 Aug 2026, 19:49 Cambelt will be a piece of cake for you with small hands, Jim! You might need some more heft to get the crank bolt out - but they are not that tight. Supposed to be replaced - decent kits come with a new bolt. No real gotchas on these, unlike the 2.0 HDi with the hidden, different sized, bolt down the back!! It's a bit tricky to rotate the crank and wiggle the locking pin (for holding the crank for bolt undoing / tightening only) in over the exhaust single handedly... I've never managed to get the belt back on over the tensioner, but it's easy enough to fit the belt first, then bolt on the tensioner afterwards.
I'm almost looking forward to this job!
That's a good thought Mick... I absolutely hate the smell of Copydex. Makes me feel sickmickthemaverick wrote: 26 Aug 2026, 21:43 On my first C5 I had them splitting and no hot staples back then. I actually 'Wallpapered' the inside of the liners with good old blue tarpaulin and spray on upholstery glue, Copydex I believe I used. Repaired and reinforced at the same time!![]()
- x 8124
Ok The only day I cannot do is tomorrow, so any other day including today is fine Jim. Up to you.
Huskyxantia
- x 915
Fibre glassed a wheel arch liner when I was in my 20s that was fun , messy , but fun . Rubbed down primed and sprayed black. My mates poked fun at me saying it was the newest thing on the car a waste of time because no one sees it . I knew it was there . I was very proud of the whole thing .
Husky.
- x 8406
I'm busy installing a new cooker for the youngsters today Mick, the long weekend is fully booked and really, there's absolutely no rush and whilst the bathroom is being rebuilt there's no space around here due to big white vans being present!mickthemaverick wrote: 27 Aug 2026, 06:20 Ok The only day I cannot do is tomorrow, so any other day including today is fine Jim. Up to you.![]()
Yesterday, they completed the plastering, got most of the new floor down and are all good to crack on next week. With any luck I should have a nice new functional bathroom by the weekend and then I'll not need to visit friends and family for a shower
- x 8406
The Picasso did me proud yesterday - loaded up to the gunwales with an old cooker and much other random detritus that had accumulated in the youngsters' garage... You'd have been proud Matt
Makes me pleased I did not get rid of said vehicle a few weeks back. She still has her uses
The new cooker is a bit posh. First time I've seen an induction hob in action - it's as quick, or quicker perhaps, than gas. I was impressed!
- x 2354
Brilliant, it's always nice when you are "getting your money's worth" isn't it!CitroJim wrote: 29 Aug 2026, 05:58 The Picasso did me proud yesterday - loaded up to the gunwales with an old cooker and much other random detritus that had accumulated in the youngsters' garage... You'd have been proud Matt![]()
Yes, we've got one too, it's great. I find that as the hob doesn't really get hot (only by conducted heat back down from contact with the pan) that the glass top is easy to keep clean. Most spillages just wipe off and an occasional (maybe yearly? Not often at all) a quick run over with a scraper blade takes anything more stubborn off.Makes me pleased I did not get rid of said vehicle a few weeks back. She still has her uses
- x 8124
I was married for 23 years and used the scraper blade frequently, but she was still there at the end!MattBLancs wrote: 29 Aug 2026, 08:12 .................... a quick run over with a scraper blade takes anything more stubborn off.
Come on Jim there is an old thread of mine for such things, unfortunately a bit neglected since March 22nd 2026!....deserves a bit of a revisit with today's quirky turn of phrase from your good self.
Word/Phrase of the Day! viewtopic.php?t=76155&hilit=phrase+of+the+day
Congrats on the proper spelling, I imagine in the phrase "full to the ......." the spelling has morphed in common usage, to be more like the surname of Sally, the 400 metre Hurdles Gold medal winner at at the 1992 Barcelona Olympics, although she does use a double ll at the end!
- x 8406
Indeed, Neil, it has indeed morphed, as has several other words in current use... A common occurrence now is the spelling of the device your foot is in contact with when driving or cycling. Peddle is rapidly becoming the accepted alterative spelling of pedal.NewcastleFalcon wrote: 29 Aug 2026, 11:46 Congrats on the proper spelling, I imagine in the phrase "full to the ......." the spelling has morphed in common usage...
As ever was. Despatch and dispatch are interchangeable. Here's a question: what's the correct spelling of the device that holds and retains brake pads on a disc brake setup?
I've been away for a couple of days due to the enormous generosity of my eldest granddaughter. She gave me a very virulent tummy bug and not only to me but to her mum and dad too. Only her little sister escaped unscathed!
It was an evil little violent bug but happily, a short-lived one. It caused me to loose over 2Kg of body weight and when you're as light as I am, that's a lot. Even my smart scales expressed surprise
My level of body fat only reduced by 0.5% and now sits at 18%...
I have a lovely meme about nasty bugs I used on a Facebook post; sadly the mods would frown if I posted it here
If you want to see it, go to Facebook and search for 'Twonks Nasty Bug'
Today, with my driveway uncluttered by Tranny Vans, I'll be dragging Bluebell out of the garage and prepping her for a car show on Saturday. She badly needs a wash and that will have to be by use of buckets. Luckily, being small, like me, it won't take many buckets...
- x 2354
Oh heck, hope you are well clear of that bug now Jim!
- x 1995
Quite a misogynistic comment that Mick....we do have a few Women members and we are not a 1970's "Mens Club"mickthemaverick wrote: 29 Aug 2026, 08:18
I was married for 23 years and used the scraper blade frequently, but she was still there at the end!![]()
Huskyxantia
- x 915
"Fair point, Alasdair, but calling out a '1970s Men’s Club' with a top-heavy Michelin Man as your profile picture is peak forum irony!"Stickyfinger wrote: 31 Aug 2026, 13:26Quite a misogynistic comment that Mick....we do have a few Women members and we are not a 1970's "Mens Club"mickthemaverick wrote: 29 Aug 2026, 08:18
Husky.
- x 8124
The comment was a joke and SWMBO thought it amusing. !!
- x 8406
Oh yes, this morning I'm all back to normal Matt and up early for my weekly trip to Tesco for my stock of gluten, soya and lactose-free fuel
I was well enough to give Bluebell at good clean inside and out yesterday and here she is after her bath
As we still have a hosepipe ban in force I had to use buckets of water to rinse her down. I expect I used just as much water doing it that way but hey-ho, you have to abide by the rules...
I gave her interior a good hoovering and whilst I had the hoover out I gave the posh van's interior a good clean - it had got a bit rough after much ferrying of children around, transporting parkrun kit and personnel and a couple of tip trips.
In the process it seemed a shame to erase some small dusty footprints across the cargo area floor and the back of the folded down seat back; it's autumn's favourite way of getting in the car - in through the tailgate and walk across the cargo area to her seat. It's something she can't do in her mum or dad's car. In mine she can stand up in the back!
Saturday was very special. I was highly honoured to walk parkrun with a good friend of mine with terminal cancer. It was their* first time completing a parkrun since their very major surgery in November. It took us 1 hour and 16 minutes - a full hour slower than the fastest finisher!
We did a lot of talking during the walk
* The use of the they/their pronoun as this person is gender-neutral.
