- x 2341
- x 2341
And key image of the day
Break for late lunch now
- x 2341
Ah my stretch boot and fitting kit has arrived, is this how it's done?
- Spoiler: show
- x 2341
Angle grinder plus old flywheel bolts = chase out the thread locking compound.
Crankshaft oil seal installation tool from the Morrisons Greek Style Yogurt range 90x110x7 "from stock" due to hoarding tendencies...
Knackered, more tomorrow
- x 8391
Great work Matt! Loving your oil seal installation tool
That's a fine cone you've grown on your head!
ozfrog
- (Donor 2026)
- x 76
Does the VIN also indicate what engine is in the car?
If it does, as I believe it should, then what I've been told about the engine in my 406s so far is incorrect. The VIN for both of them have 'RHZ' in the VIN - 109 HP. Okay, everyone calls it the 110 HP engine.
Who would have thought!
Cheers,
Andrew
Andrew
ozfrog
- (Donor 2026)
- x 76
You people use strange names for things!MattBLancs wrote: 17 Aug 2026, 16:20 … proper clip without the proper pliers - a pair of nail pulling pincers can stand in fairly well.
I'd thought of using jubilee clips -
"dedicated" CV Clip Pliers,
I found out what "Jubilee" clips are - worm drive hose clamps
Clacton? Clacton-on-Sea? Constituency? What on earth?Huskyxantia wrote: 17 Aug 2026, 20:38 A now retired stripper from Clacton, they just call the ole fella crusty now , due to his age
And a retired stripper?
Cheers,
Andrew
Andrew
- x 2341
Yes, certainly confirms what was originally in there
- Spoiler: show
"Commander Lumley Robinson" (so says Wikipedia below) apparently invented and named them Jubilee clips but it's since become generic. Also Biro, Hoover, Velcro and lots of others that'll come to mind when I'm a bit more awakeozfrog wrote: 19 Aug 2026, 07:04You people use strange names for things!
Amazingly actual genuine jubilees are still sold. Quite like when the original is still knocking about more than 100 years after first devised
https://en.wikipedia.org/wiki/Jubilee_Clip
- x 1488
Handy...! On your foray into UK / European terms, it's 109 BHP (Brake Horse Power) but the figures are usually quoted in PS which is a German measure ( PS stands for Pferdestärke, a German word that translates to "horse strength". It is the metric measurement for engine power, commonly used by European car and motorcycle makers. One PS equals roughly 0.9863 of a standard mechanical horsepower (bhp/hp), meaning the values are almost the same.) But they are also often quoted in brackets in kW....ozfrog wrote: 19 Aug 2026, 06:27 The VIN for both of them have 'RHZ' in the VIN - 109 HP. Okay, everyone calls it the 110 HP engine.
Thread hijack, Matt, Sorry!
- x 2341
No problem at all, a good distraction from the rain that's stopped me before I have even started today!
(Sorry for wonky picture in the larger view)
Huskyxantia
- x 908
Crusty nuts ..(stage name)... you need to move to the uk your have a blast ... in second thoughts , your miss that weather of yours ..ozfrog wrote: 19 Aug 2026, 07:04You people use strange names for things!MattBLancs wrote: 17 Aug 2026, 16:20 … proper clip without the proper pliers - a pair of nail pulling pincers can stand in fairly well.
ENDING NOTE.
Brilliant set of photos and info here Matt this may well could be of use to someone one day with the same job . Top work.
Husky.
- x 2341
Weather seriously getting on my nerves at present flip a coin every 15 minutes and flick between:
Proper cloud burst downpour
And
Hot sunshine baking down.
New flywheel on. A deep socket a good fit in the flywheel spigot hole is a MASSIVE help as trying to precisely align the flywheel (8 bolt holes but also a dowel pin too. Which is a stopped hole in the flywheel and hence not visible from the front!) quickly becomes an arm aching patience test. Thusly:
Nipped inside to grab the (previous generation) torque settings for flywheel bolts. T50 torx, from the Haynes:
Stage 1 is 25 Nm
Stage 2 is fully loosen
Stage 3 is 8 Nm (can't see the overcoming the loctite personally! Will need to break out the 1/4" inch drive torque wrench as my 3/8" drive just not go below 20 Nm!)
Stage 4 is 30 Nm
Stage 5 angle tighten 90 degrees
Stage 6 is drop torque wrench and try to reconnect arms back into sockets
And
Thank you!ENDING NOTE.
Stage 1 is 25 Nm
Stage 4 is 30 Nm
ozfrog
- (Donor 2026)
- x 76
I like Stage 6 the best.
Cheers,
Andrew
Andrew
- x 2341
I'm looking forward to that bit!
8Nm is 71 inch-pounds (as that's what my little cheap 1/4" drive torque wrench uses)
All together: Ahhhhh it's nowt but a baby!
- x 2341
It's in blinding mode, couldn't see the screen
but if blue sky so getting cracking.
Eating going to have to wait a bit
