x 2287
Unread post by MattBLancs »
This morning
x 2287
And key image of the day
Break for late lunch now
x 2287
Ah my stretch boot and fitting kit has arrived, is this how it's done?
Spoiler: show
Dunce's hat?
Dunce's hat?
:P
x 2287
Angle grinder plus old flywheel bolts = chase out the thread locking compound.
Crankshaft oil seal installation tool from the Morrisons Greek Style Yogurt range
90x110x7 "from stock" due to hoarding tendencies...
Knackered, more tomorrow :)
x 8252
Great work Matt! Loving your oil seal installation tool :D
That's a fine cone you've grown on your head!
ozfrog
(Donor 2026)
x 70
Unread post by ozfrog »
RichardW wrote: 17 Aug 2026, 07:52
ozfrog wrote: 17 Aug 2026, 07:21
I’ve always been told that it’s a ‘90’, so that’s what I’m sticking with until I know differently.
Easy to tell - 90 only has 1 air pipe over the engine, 110 has 2 (due to the intercooler).
Does the VIN also indicate what engine is in the car?
If it does, as I believe it should, then what I've been told about the engine in my 406s so far is incorrect. The VIN for both of them have 'RHZ' in the VIN - 109 HP. Okay, everyone calls it the 110 HP engine.
Who would have thought!
Cheers,
Andrew
ozfrog
(Donor 2026)
x 70
MattBLancs wrote: 17 Aug 2026, 16:20 … proper clip without the proper pliers - a pair of nail pulling pincers can stand in fairly well.
I'd thought of using jubilee clips -
"dedicated" CV Clip Pliers,
You people use strange names for things!
I found out what "Jubilee" clips are - worm drive hose clamps
Huskyxantia wrote: 17 Aug 2026, 20:38 A now retired stripper from Clacton, they just call the ole fella crusty now , due to his age
Clacton? Clacton-on-Sea? Constituency? What on earth?
And a retired stripper?
Cheers,
Andrew
x 2287
ozfrog wrote: Yesterday, 06:27 Does the VIN also indicate what engine is in the car?
Yes, certainly confirms what was originally in there
Spoiler: show
306 engine bay with little tweak from standard. (Not mine but appreciate it from across the internet)
ozfrog wrote: Yesterday, 07:04
MattBLancs wrote: 17 Aug 2026, 16:20 I'd thought of using jubilee clips -
"Commander Lumley Robinson" (so says Wikipedia below) apparently invented and named them Jubilee clips but it's since become generic. Also Biro, Hoover, Velcro and lots of others that'll come to mind when I'm a bit more awake :)
Amazingly actual genuine jubilees are still sold. Quite like when the original is still knocking about more than 100 years after first devised
https://en.wikipedia.org/wiki/Jubilee_Clip
x 1472
ozfrog wrote: Yesterday, 06:27 The VIN for both of them have 'RHZ' in the VIN - 109 HP. Okay, everyone calls it the 110 HP engine.
Handy...! On your foray into UK / European terms, it's 109 BHP (Brake Horse Power) but the figures are usually quoted in PS which is a German measure ( PS stands for Pferdestärke, a German word that translates to "horse strength". It is the metric measurement for engine power, commonly used by European car and motorcycle makers. One PS equals roughly 0.9863 of a standard mechanical horsepower (bhp/hp), meaning the values are almost the same.) But they are also often quoted in brackets in kW....
Thread hijack, Matt, Sorry!
x 2287
No problem at all, a good distraction from the rain that's stopped me before I have even started today!
(Sorry for wonky picture in the larger view)
Huskyxantia
x 847
Unread post by Huskyxantia »
Crusty nuts ..(stage name)... you need to move to the uk your have a blast ... in second thoughts , your miss that weather of yours ..
ENDING NOTE.
Brilliant set of photos and info here Matt this may well could be of use to someone one day with the same job . Top work.
:-D
x 2287
Weather seriously getting on my nerves at present flip a coin every 15 minutes and flick between:
Proper cloud burst downpour
And
Hot sunshine baking down.
New flywheel on.
A deep socket a good fit in the flywheel spigot hole is a MASSIVE help as trying to precisely align the flywheel (8 bolt holes but also a dowel pin too. Which is a stopped hole in the flywheel and hence not visible from the front!) quickly becomes an arm aching patience test. Thusly:
ENDING NOTE.
Thank you! :)
Nipped inside to grab the (previous generation) torque settings for flywheel bolts. T50 torx, from the Haynes:
Stage 1 is 25 Nm
Stage 2 is fully loosen
Stage 3 is 8 Nm (can't see the overcoming the loctite personally! Will need to break out the 1/4" inch drive torque wrench as my 3/8" drive just not go below 20 Nm!)
Stage 4 is 30 Nm
Stage 5 angle tighten 90 degrees
Stage 6 is drop torque wrench and try to reconnect arms back into sockets :-D
ozfrog
(Donor 2026)
x 70
I like Stage 6 the best.
Cheers,
Andrew
x 2287
ozfrog wrote: Yesterday, 12:16 I like Stage 6 the best.
I'm looking forward to that bit!
8Nm is 71 inch-pounds (as that's what my little cheap 1/4" drive torque wrench uses)
All together: Ahhhhh it's nowt but a baby!
:-D
x 2287
It's in blinding mode, couldn't see the screen :rofl2: but if blue sky so getting cracking.
Eating going to have to wait a bit
