Huskyxantia
x 909
Unread post by Huskyxantia »
MattBLancs wrote: 17 Aug 2026, 18:01 One of these bolts lives up high on the back of the engine, tucked up nice and warm with the turbo. The other down low front of the engine. Guess which is which ?
(Not sure how long without an under tray)
Pretty sure this was crusty horns relation one hung low , hence the rusted one and a clean one , he's now retired from the Clacton strip scene
:-D
Huskyxantia
x 909
MattBLancs wrote: 17 Aug 2026, 16:55 Or specifically, looking a lot less like this:
Ive not seen one that bad , has the car been in flood water ? The clips are available on ebay its just getting the right size , I once drew around one on paper then did the measurements sent photo of clip , my drawing , with all measurements written down and the seller found it , it might of been one of the ebay links in your thread.
:-D
x 8126
Huskyxantia
x 909
I'd say the 2nd link is the one
:-D
x 2342
Unread post by MattBLancs »
Huskyxantia wrote: 17 Aug 2026, 20:47
Don't think / hope!! It's been in flood water, and Colne (where I bought the car from) isn't by the sea :rofl2:
I remember my blue 308 clutch clip was a bit rusty, but this is undoubtedly worse. I'll try and extract it tomorrow and take dimensions. Annoyingly this bit isn't part of the slave cylinder, effectively it's the end of the hose I think.
x 2342
mickthemaverick wrote: 17 Aug 2026, 21:00 How about:
https://www.ebay.co.uk/itm/205392845016 ... R8z4zpSCaA
OR:
https://www.ebay.co.uk/itm/333607405041 = dimension pic on this one :-D
Thanks Mick, will have a measure in the daylight tomorrow :)
x 2342
RichardW wrote: 15 Aug 2026, 18:43 Are you planning the drop the box, or leave it in and 'letterbox' it? Former requires the subframe extensions removing, which in turn needs the front bumper off to access the bolts for them (although if the arms have been done these will have been out to do them, so shouldn't be too bad. Latter requires that you drop the side of the subframe to make enough room to get the end of the box over the extensions - and the bolts like to seize in and spin the 'captive' nuts (which are only held in with a bit of plastic FFS!). Might be an unenviable choice....!
Just checking here's a quick image of first generation 308 underside:
These bits = sub frame extensions?
I recall them on the 2011 grey 308 but looking on the red 308 (2016) I don't think there is such a part, certainly not on this one (and no sign of it being removed / looking as though absent. Pictures tomorrow.
Above image from https://share.google/HtPMePOEvxuKvgGQx
x 2342
Box and engine dropped a little, maybe forward a touch, then separate and box down and out, forward of the subframe (remaining in place) looks viable??
Engine and box together on engine hoist, held by gearbox lug. As box fixings loosened, engine then jack + piece of wood to support from below. That plastic sump puts the wind up me as to bear any load. May even go for foam block on wood on jack to ensure even distribution of the load as far as I can.
Upper engine mount top "link" off, but other mount in place, lower rear engine mount off, to give some capacity for movement.
About £60 gamble! (Plus oil everywhere and car not ready for my self imposed deadline= Friday) https://ebay.io/m/onBbul
Huskyxantia
x 909
Excellent stuff its like being there aswell .
:-D
x 1489
Looks like the 308 does without the extensions / crash bars unlike the C4 Picasso and 3008 / 5008 - which saves you a job!
I expect you will need to rotate the box forward once free of the engine to get the diff out past the subframe.
x 2342
RichardW wrote: 17 Aug 2026, 22:31 Looks like the 308 does without the extensions / crash bars unlike the C4 Picasso and 3008 / 5008 - which saves you a job!
Woohoo! Will take the little wins whenever I get them! :)
Yep, got you. Think you're right, it's a big lump out the back and the whole assembly would have to come well forward to clear without rotating.
x 2342
CV boot kit, Eolys additive kit both showing as the to arrive today.
Hoping the current rain goes away shortly then I can crack on today. If box isn't out by lunchtime I'll be disappointed
x 8400
Fingers crossed Matt [-o<
MattBLancs wrote: 18 Aug 2026, 06:56 Hoping the current rain goes away shortly then I can crack on today.
Rain. What's that then?
x 8126
CitroJim wrote: 18 Aug 2026, 08:06 Fingers crossed Matt [-o<
I think it's something Kings and Queens do, .....................oh no, silly me, thats reign!! :sulk:
x 2342
A bit of rain yesterday evening, and more over night plus this morning. Just stopped in the last half hour and brightening up a bit now. Really chucked it down about 8 pm last night.
In other news:
viewtopic.php?p=874119#p874119
