x 1488
ozfrog wrote: 17 Aug 2026, 07:21
I’ve always been told that it’s a ‘90’, so that’s what I’m sticking with until I know differently.
Easy to tell - 90 only has 1 air pipe over the engine, 110 has 2 (due to the intercooler).
x 2341
Unread post by MattBLancs »
CitroJim wrote: 17 Aug 2026, 05:46 That starter motor :shock:
Yep, cable ties on CV boots don't work - unless, it seem, they are on the outer boot of one driveshaft on a certain red AX I know...
I guess AX driveshafts are so tiny and spin so slowly they can get away with it!
I'd call that "the exception to the rule" eh Jim! Is it a nice big chunky cable tie, wide?
Actually I've realised I don't know what cable ties are defined by / what the usual widths are...
Looking here https://ebay.io/m/3MrEUv it seems:
2.5, 3.6, 4.8, 7.6, 8, 9 or 12.7mm wide.
12.7 (half inch) sounds unusually large for a cable tie.
The ones on this CV boot I'd guess must be 3.6 or 4.8 at the most. Definitely not strong enough to pull the boot securely onto the CV.
x 2341
RichardW wrote: 17 Aug 2026, 07:52
Good idea, I was trying to remember the shift pattern of BE4 (90) Vs ML5 (110) as think that also separated them
x 8117
I use 8mm ties on boots and they seem to work well, need quality ones though, not the ebay Chinese variety!! :-D
Huskyxantia
x 908
Unread post by Huskyxantia »
Matt ,get the metal ones, i made the mistake of using the black thick ones and they will come off after a while plus a tool for crimping then is a must
Other wise you may end up doing the whole job again and grease everywhere
:-D
PaulC5
x 683
Unread post by PaulC5 »
When an outer clip on the Cactus cv joint snapped I tried a cable tie - useless, then a metal clip without a proper tool - again useless and then a jubilee clip 70 - 90 mm from Halfords which worked. Done 2 years ago, been through 2 MOTs and still there. Now about £4 from Halfords.
x 2341
PaulC5 wrote: 17 Aug 2026, 15:53 When an outer clip on the Cactus cv joint snapped I tried a cable tie - useless, then a metal clip without a proper tool - again useless and then a jubilee clip 70 - 90 mm from Halfords which worked. Done 2 years ago, been through 2 MOTs and still there. Now about £4 from Halfords.
I have managed to do the proper clip without the proper pliers - a pair of nail pulling pincers can stand in fairly well.
I'd thought of using jubilee clips - but it depends on what hub clearance there is (pretty tight when I've been considering it) the bulk of the worm drive bit cleared ok on the Cactus = good to know.
I've recently bought some cheap "dedicated" CV Clip Pliers, but yet to actually christen them! I think I've some metal clips stashed somewhere, so long as I can find them, a proper fix is imminent
x 2341
Any recommendations for the clutch bleed retaining wire clip? The red 308's item is just a thin rusty shadow of it's former self!
This sort of thing, I think:
https://ebay.io/m/MpxMH0
(Quick search result for "Peugeot clutch clip" )
Something like this :
Nicked from: https://www.peugeotforums.com/threads/3 ... um=organic
x 2341
Or specifically, looking a lot less like this:
x 8117
x 2341
Precious little dimension data on that Mick - but it looks quite big. In fact looks more like a brake pipe retaining clip to my eyes. Do I spy an AI
"spewdliwer" ???
:rofl2:
x 2341
One of these bolts lives up high on the back of the engine, tucked up nice and warm with the turbo. The other down low front of the engine. Guess which is which ?
(Not sure how long without an under tray)
x 2341
Crusty horns too
x 2341
Another dump of photos.
Pipe under the sump removed (2x 10mm) but it's the next one up back if engine bay that's also hiding an engine to gearbox bolt (the clean one, above) another 10mm bolt and a house clip 8mm hex (rather than 7mm hex if the next 2x hose clips further down!)
Wheel arch liner (left) and bumper tray removed together to attack rusty fixings off the car.
Huskyxantia
x 908
MattBLancs wrote: 17 Aug 2026, 18:18 Crusty horns too
A now retired stripper from Clacton, they just call the ole fella crusty now , due to his age
:-D
