Test of forum posting speed
Forum News, Announcements and any issues you're having with the forum
x 1425
Unread post by xantia_v6 »
As part of an ongoing investigation of performance of this forum, I have temporarily disabled the indexing of new posts in the forum search system.
To determine whether this has improved forum performance, please reply here if you have an undue delay (more than 10 seconds) when making a post.
I will revert the forum back to normal configuration in a day or two after gathering some data, and will rebuild the search index at that time so that nothing is lost.
x 5621
Re: Test of forum posting speed
Approximately ten seconds to post a reply to Jim's thread. Otherwise quite quick.
Ed: 8" for this reply.
x 1905
Will take note of posting time.
EDIT
14s for this post.
x 7986
app 12 secs to post to Matt's thread earlier :)
Edit 19 secs for this
x 1425
OK, it looks like that is not the right path...
x 5621
Last reply took 48".
Vic Evans
x 153
Unread post by Vic Evans »
Testing
x 7986
Just posted a fairly long post with pics and it appeared in 9 secs. :)
Vic Evans
x 153
Vic Evans wrote: 29 Jul 2026, 13:36Testing
That took about 20 secs.
W11, Firefox, Nord VPN, Orange fibre connexion
Vic Evans
x 153
Vic Evans wrote: 29 Jul 2026, 13:39
Now about 6 secs with VPN paused
x 5621
The most recent ones have all been virtually instantaneous.
Stonehopper
x 118
Unread post by Stonehopper »
Let's see how long this takes.
12 seconds.
But the edit was less than 2 seconds.
Derek
x 5621
Approval of Iteuer took several minutes, including a CloudFare timeout.
x 1425
Ok, no more reports needed for now.
I need to investigate the forum source code and probably add some more diagnostics.
moizeau
x 428
Unread post by moizeau »
Not sure if this is useful. Just posted a reply including a link from here and my 'puter timed out. I then came out and back into the forum and it was posted.....
Pete
