Test of forum posting speed
- x 1411
As part of an ongoing investigation of performance of this forum, I have temporarily disabled the indexing of new posts in the forum search system.
To determine whether this has improved forum performance, please reply here if you have an undue delay (more than 10 seconds) when making a post.
I will revert the forum back to normal configuration in a day or two after gathering some data, and will rebuild the search index at that time so that nothing is lost.
- x 5614
Re: Test of forum posting speed
Approximately ten seconds to post a reply to Jim's thread. Otherwise quite quick.
Ed: 8" for this reply.
- x 1901
Will take note of posting time.
EDIT
14s for this post.
EDIT
14s for this post.
- x 7948
app 12 secs to post to Matt's thread earlier
Edit 19 secs for this
- x 1411
OK, it looks like that is not the right path...
- x 5614
Last reply took 48".
Vic Evans
- x 143
Testing
- x 7948
Just posted a fairly long post with pics and it appeared in 9 secs.
Vic Evans
- x 143
That took about 20 secs.
W11, Firefox, Nord VPN, Orange fibre connexion
Vic Evans
- x 143
- x 5614
The most recent ones have all been virtually instantaneous.
Stonehopper
- x 118
Let's see how long this takes.
12 seconds.
But the edit was less than 2 seconds.
12 seconds.
Derek
- x 5614
Approval of Iteuer took several minutes, including a CloudFare timeout.
- x 1411
Ok, no more reports needed for now.
I need to investigate the forum source code and probably add some more diagnostics.
moizeau
- x 428
Not sure if this is useful. Just posted a reply including a link from here and my 'puter timed out. I then came out and back into the forum and it was posted.....
Pete
