Steering fluid
Mike E
Steering fluid
Can someone please advise what steering fluid I need citroen c5 1.6hdi manual, not hydo suspension ,is it chf or lds,its a 2009 the newer model please
- x 6945
Re: Steering fluid
Only LDS or Total Fluide DA, regardless of hydraulic or metallic suspension.
Mike E
Re: Steering fluid
Also it's a salon and 110 bhp ,I keep getting confiscating answers
Mike E
Re: Steering fluid
Citroen told me it's esso atfe oil euro car parts tell me its chf so I am really confused
- x 6945
Re: Steering fluid
Don't trust anything from ECP - they haven't got a clue.
I'm telling you 100% only ever use LDS fluid. The same fluid is used in Hydractive or metallically sprung Citroen C5 X7 vehicles.
Pop your VIN up, (please post your VIN in full without spaces - it will be automatically masked from public view after submitting your post & will only be visible to staff) so I can check the actual system fitted.
The LDS fluid was used for both suspension and power steering systems regardless of suspension type. It may be that as Hydractive suspension is no longer made, they are offering an alternative as the demand for LDS becomes less. I'll be able to check when I have your VIN.
- x 6945
Re: Steering fluid
Just to confirm also that TOTAL (AT42) FLUID was used on PSA vehicles BEFORE the C5 MK I. So the C5 MK I, MK II and MK III (X7) use Fluide DA or LDS.
Mike E
Re: Steering fluid
VF7**************[VIN obfuscated, can be read by forum staff] thanks for the help
- x 6945
Re: Steering fluid
Yes, stick to LDS or Fluide DA as mentioned.
Mike E
Re: Steering fluid
Thanks Marc, I will do
malwee1
Re: Steering fluid
My car is Citroƫn 1.6 HDi 110 FAP 2011
wich one should I use, keep having deferent answers!!
here is the VIN: VF7**************[VIN obfuscated, can be read by forum staff]
PaulC5
- x 683
Re: Steering fluid
Which model of Citroen is it ?
malwee1
Re: Steering fluid
My car is a Citroƫn 1.6 HDi 110 FAP 2011 automatic (semiautomatic).
Which one should I use? I keep getting different answers!
Again VIN: VF7**************[VIN obfuscated, can be read by forum staff]
- x 1938
Re: Steering fluid
As it's a C5 (that bit is important and shouldn't be left out) then it will need LDS or Fluide DA - they are the same. Are those the two different answers you're getting?
viewtopic.php?t=53781
malwee1
Re: Steering fluid
I keep getting this two options, don't know which one is correct:
1- Orange Fluid (e.g., Total Fluide LDS)
2- Green Fluid (e.g., febi 06161/ Pentosin CHF 11S)
My car has conventional steel-spring suspension, not Hydractive suspension, that is why it is confusing, cos as they say some of them :LDS is just for Hydractive suspension!
